A+ Case Monolize ATX Full Tower Case
The Case - External
Close-up Monilith by A+ Case
The external of the case is pretty striking with a plain black look achieved by what looks like matt black powder coating. The front of the case is a matte plastic with a swing door.
monolith side on
monolith side on
I thought I'd use two different styles of lighting to give you a good idea of how the case looks in different situations. When I first took a look at the case and realised the front had plastic on it I was a little skeptical (being an all Aluminium man myself), but the case does look good sitting beside my desk.
monolith case fan side
Here we see the huge fans that I presume gave the case its name. Large they are indeed, although you do get used to the size after a while. They certainly are a big feature of the case. The fans look a little 'stuck on' when you take a closer look at them. The join in between the case and the plastic shroud used is visible and would irk those who are perfectionists with their cases.
mopnolith case side
The opposing side of the case has ventilation holes drilled into it at the top and side. At first I wasn't sure what to make of them but as time has goes on I realise the idea is to draw airflow across the case from the large fans through the back of the case. This does actually work and right now I can feel air blowing through the case and out the other side. We will see whether this is effective or not on the test results page.
monolith case
The front of the case is very reflective on the middle panel. Also note that fingerprints are very easy to imprint on the case and not so easy to get off! The A+ symbol is cut inside the door front and not so easy to see in the light. More on that later.
front door open
The matte look continues on inside the dook and I like the look here. The on/off button is fairly solid and doesn't rattle and the same goes for the reset button.
front fan speed buttons
The case front also has buttons to turn on/off the fans and ramp up and down their speed. These again are pretty well made and make a satisfying "click" when pressed. I think this is a handy feature to have on a case such as this.
side panel
The side panel is set into the plastic side of the case and could cause hassle if you have a desk that encloses the case at the side.
in the dark
The case front lights up nicely in the dark. It's a cross between those cases that have too much 'bling' and those that are plain and simple. Having said that, if you do not like branding I don't think this case is for you. Note that there is a button inside the door that turns this light on and off.
case side fans lit
The fans also look pretty nice in the dark too. On my case the colour did not quite match on the fans but I didn't notice until I set the case up to take this shot. Again, all of the lights can be turned off.
External Build Quality
The external build quality is pretty nice overall. There is a slightly plastic feel to the front of the case but everything seems to be put together well so it doesn't lose too many marks for that.
«Prev 1 2 3 4 5 6 Next»
11-09-2007, 20:18:12
Toxcity
Very well written review, Kemp.. As always!
Looks as though it is a nice case.
Loving the Monster fans!Quote
11-09-2007, 20:31:40
Rastalovich
Meh, not a case for me. Not on the external looks either.
But I`m over 35, so I have an excuse.
In all seriousness tho, the internals of the case closely resemble the Thermaltake XaserII I have laying empty next to me. The lower drive area has been rotated and rejigged, but even looking at the front - it has the same pinching insertion things u stick to u`r devices. (the XaserII comes with a temp and fan control that fits into the top 5.25 bay, which I removed cos I never got it working >.< )
Those pci blank plate things are a pita without the top piece thing, good to see the inclusion of that to the spec.
Looks like a copy to me. Pretty darn heavy solid metally case ?Quote
11-09-2007, 21:25:44
Aqua-Pc's
Would you like some case with your fans Quote
12-09-2007, 12:09:12
mrapoc
Would you class it as heavy? If adding front and rear fans brought cpu coolingness up to scratch I would deffo consider this as a tj05 replacement Quote
12-09-2007, 17:11:06
FarFarAway
Yes it is heavyQuote
