A+ Case Monolize ATX Full Tower Case
Test Results
Test Results
Here's what happened up against a Silverstone TJ09S with only stock fans left in:
testing
The only place that the Monolize let itself down was in CPU temperature where it trailed the Silverstone by some distance. I have a feeling this is due to the non-standard side-through air passage in the Monolize. The rest of the temperature scores show a pretty competitive cooling solution from the Monolize case.
If you're looking to get this case and want a cool CPU I would suggest adding a front and rear fan for better airflow as that is what the ATX standard intended.
Still overall a pretty decent performance from the Monolize.
«Prev 1 2 3 4 5 6 Next»
11-09-2007, 20:18:12
Toxcity
Very well written review, Kemp.. As always!
Looks as though it is a nice case.
Loving the Monster fans!Quote
11-09-2007, 20:31:40
Rastalovich
Meh, not a case for me. Not on the external looks either.
But I`m over 35, so I have an excuse.
In all seriousness tho, the internals of the case closely resemble the Thermaltake XaserII I have laying empty next to me. The lower drive area has been rotated and rejigged, but even looking at the front - it has the same pinching insertion things u stick to u`r devices. (the XaserII comes with a temp and fan control that fits into the top 5.25 bay, which I removed cos I never got it working >.< )
Those pci blank plate things are a pita without the top piece thing, good to see the inclusion of that to the spec.
Looks like a copy to me. Pretty darn heavy solid metally case ?Quote
11-09-2007, 21:25:44
Aqua-Pc's
Would you like some case with your fans Quote
12-09-2007, 12:09:12
mrapoc
Would you class it as heavy? If adding front and rear fans brought cpu coolingness up to scratch I would deffo consider this as a tj05 replacement Quote
12-09-2007, 17:11:06
FarFarAway
Yes it is heavyQuote
