AeroCool Sixth Element White edition
Introduction and Tech-Spec
The Sixth Element White edition forms part of the line up of cases from AeroCool's Performance Gaming System range.  The Sixth Element wears the Red badge of the Professional Series, which puts it roughly mid way in the PGSline up.  The case is also available in Black, with either Blue or Red accented interiors.  In this review we shall be taking a look at the White edition.
The case is a Full/Mid-tower, making use of 6mm Japanese Steel and, as would be expected, fair amount of plastic for the outer shell and detail areas.  The case is windowed and comes with two 140mm fans pre installed.
Before writing this review I got to thinking what exactly the Sixth Element was.  As alluded to on the home page if Luc Besson is to be believed we've already established the nature of the 5th Element in the form of the not unattractive, white bandage clad, Milla Jovovich.  A quick trawl of the inter-web reveals more than a few opinions on the subject of the nature of the mysterious Sixth Element, with everything from Void, Consciousness, Space, Light and Darkness vying for the title.  So have AeroCool used any of these Holistic concepts to shape their design ethos? Doubtful.  In purely chemical terms of course the sixth element is Carbon.   Has the case been made from Carbon fibre?  Afraid not (at £78 that's not really likely is it now, and neither is a carbon fibre effect coating so don't go getting excited there either).  So why Sixth Element? Apart from it being a rather cool name of course.  Well it may just be coincidence, but there are certain similarities between the look of the case and the lines of the new Lamborghini Concept car, the Sesto Elemento (Sixth Element in Italian if you hadn't guessed).
All that said whatever the design influences are for case and whatever the inspiration for the nomenclature what we want to know is how good is it.
Case Type
Full Tower
SECC 0.6mm
Compatible Motherboards
ATX and Micro ATX
Chassis Dimensions
510(H) x 197(W) x 530(D)
Drive Bays
4 x 5.25" (External) with one 3.5" converter / 6 x 3.5" HDDs (internal)
Expansion Slots
7 Slots
Max length space available for PCI cards
280 or 400mm with middle HDD cage removed
I/O Ports
2 x USB 2.0 / e-SATA / Mic & headphone (AC97 & HD audio)
Cooling options
Front - 1 x 140mm LED fan (included), Roof - 1 x 140mm LED fan (included), Back - 1 x 120mm fan (optional), Side panel - 2 x 120mm fan (optional)
140mm Fan Specifications
Rated voltage
Starting voltage
Rated Current
0.36A +10% Max
Power Consumption Speed
4.32W +10%Max
Fan speed
1500 ±10%
Max AirFlow
Max Static Pressure
«Prev 1 2 3 4 Next»
10-11-2011, 07:41:37
The front panel looks pretty funky but I don't like the side panel and the inside looks a bit basic too. Personally I think it's a bit highly priced and should be around £60, there are better cases for ~£77, 400/500R for example.Quote
10-11-2011, 07:43:39
When are these manufacturers gonna get the message - if its a new case us enthusiasts expect at least 1 USB3.0 on the front with a suitable motherboard header, and if you're gonna put a side window on there - WE DON'T WANT ANY VENTS! and if you are gonna go to the trouble to paint the interior make all the internal wiring black! tbh I think this case is pointless - get a fractal R3 instead as they're about the same money.Quote
10-11-2011, 07:44:34
The exterior design puts me off big time, especially the front, these are the kind of cases PC World use to sell in their stores 5-6 years ago. Looks too cheap imo, could have been much better.Quote
10-11-2011, 08:04:43
seems ok but doesnt live up to the "one up" an orange haired milla jovavitch takes a lot more than this........
nice case
but sorry aerocool
you need to go visit the nameingway!!!Quote
10-11-2011, 10:22:49
its no lian li
but it is a nice looking case...
and for the price, with a bit of tweaking, it could be good, i.e. cut a bigger window and ditch the vents in the current one...
if you did it with say a black watercooling setup, and a black mobo, and graphics....?Quote
