Akasa Revo Thermaldynamic CPU Cooler
Test Setup and Testing Method
Test Setup
The following Test Setup and Method was used:
CPU: Intel Core2Duo E6700 @ 3.33Ghz
Motherboard: XFX 650i Ultra
RAM: 2gb Mushkin XP2-6400 4-4-4-12
HDD: OS - 160gb Hitachi Deskstar SATA II
Power: Zippy 500w
Case: A+ Case Monolize
Graphics Card: Sapphire X1600Pro with Artic Cooling Accelero S2
OS: Windows XP Professional
The Temperature was at a pretty constant 25°C room temperature and the system temperature was 31°C.
Artic Silver 5 was applied onto both of the heatsinks to give as fair a comparison as possible. Please note that as AS5 "cures" (about 200hours and at least 2 cycles), the temps are likely to drop 1-3°C. Due to time constraints neither cooler had this luxury, and this was a fair comparison.
For the testing I had the E6700 clocked both at stock settings of 266 x 10 (2.66GHz) @ 1.3v and 330 x 10 (3.3GHz) @ a fairly high 1.45v to really push the coolers.
Temperatures were logged using CoreTemp monitoring software. Temperatures were checked with a thermal probe and found to be fairly accurate.
For idle temperatures I left the PC for 30mins then recorded the idle temperature every 10 seconds for 5 minutes, making sure I did not use any program that was not already running at windows startup.
For the load temperatures I ran an instance of prime 95 with in-place large FFT's for maximum heat and power consumption, as well as an instance of [email protected] set to take up any spare cycles of the CPU. Once again I left this for 30mins then recorded the temperatures over a 5 minute period.
For comparison I used Intels stock cooler, the Scythe Infinity and Asus's Triton Cooler . Note that for the testing with the Asus Triton 75 testing with a fan I used the same fan as on the Scythe Infiniy for parity and fairness.
On to the installation..
«Prev 1 2 3 4 5 6 Next»
12-10-2007, 19:41:32
Brooksie
Looks sexy £30 bit OTT though, since you can get a Freezer pro for about £15 and that does just fine.Quote
12-10-2007, 19:52:52
Mr. Smith
For £40 I would NOT buy that cooler, 120 ultra ftw!Quote
12-10-2007, 19:53:41
FarFarAway
Indeed, though the price is as below, $40
Just what I thought, but it is new technology and R&D costs ££'sQuote
12-10-2007, 20:01:33
Rastalovich
Ah well.
It has to be said, I started reading the review (excellent again btw) with a pretty optimistic slant - especially with the idea of the tech involved.
To be fair, it looks an equiv cooler of a stock Intel (give or take minimal temps), but quieter. That in mind, the price is OTT imo.
Agree with the conclusion tbh. (however personally disappointed a bit)Quote
16-10-2007, 20:48:06
FarFarAway
Please note that I have now added a note from Adrian Young, Akasa's marketing directorQuote
