Anidees AI Crystal Tempered Glass Case Review
Up Close: Â Interior
Having carefully lifted off the side and front panels it’s finally time to take a look inside. Â On doing so, three thoughts immediately spring to mind. Â First, where are the cable management holes. Â Second, where are the drive cages, Â Third, what’s that plastic thing towards the front? Â Don’t worry chaps, all will be revealed. Â While we’re here though, we thought it a shame that they couldn’t get the Anidees Logo sticker on straight.
Â
As it turns out, the lack of cable management holes, and the nature of the plastic thing are one in the same. Â The “plastic thing” is actually a clever little cover for the two cable management holes which lie beneath it. Â The cover is moulded and angled in such a way as to allow major cables such as the 24 pin ATX, and the GPU cables to pass trough from behind and emerge exactly where they are needed. Â We’ll see in the build section how effective it is at both covering the cables whilst allowing their passage.
Â
As with a lot of cases these days the AI has a false floor covering the PSU area below. Â We think that while this is nice in many cases, it’s absolutely essential in a case with as much glass in it is this one. Â Although it is largely devoid of features, the false floor does have a handy dandy cable management hole. Â We do though think it’s perhaps a little large and could done with being closer to the motherboard as well as perhaps rotated 90 degrees.
Â
The rear of the AI sports 7 vented PCI slot covers as well as a 140mm white LED fan. Â Up in the roof we can again see the mounts for 120mm and 140mm based cooling solutions, and at first glance there appears to be a decent amount of room up there for mega radage.
