Antec P180b ATX Case
Specification
Taken from Antec’s product page:
A case without compromise, whether Silver or Black
The P180 is truly a revolutionary breakthrough in case design. Dual chambers isolate the power supply and CPU into separate cooling zones with up to 5 configurable fans. Three-layer sound-deadening panels dampen noise even in very high-performance systems. Ease-of-use, sleek design and Antec’s reputation for quality make the P180 worthy of being the first in a new category we call the Advanced Super Mid Tower.
Features:
* Unique upper and lower chamber structure The power supply resides in a separate chamber to isolate heat from the system and lower system noise
Â
* Innovative three-layer side panels and front door (aluminum, plastic, aluminum) dampen system noise, making this one of the quietest cases available
Â
* Cooling System:
– 1 rear (standard) 120mm TriCoolTM Fan with 3-speed switch control
– 1 top (standard) 120mm TriCoolTM Fan
– 1 lower chamber (standard) 120mm TriCoolTM Fan
– 1 front (optional) 120mm fan
– 1 middle (optional) 120mm fan to cool graphics cards
– Upper drive cage can be used as a duct to provide fresh air to graphics cards
* Maximum expandability with 11 Drive Bays
– External 4 x 5.25″; 1 x 3.5″
– Internal 6 x 3.5″ for HDD
Â
* Motherboard: Fits micro and standard ATX
Â
* Double hinge front door designed to open up to 270º
Â
* 7 Expansion Slots
Â
* Front Ports
– 2 x USB 2.0
– 1 x IEEE 1394 (FireWire®, i.Link®)
– Audio In and Out
Â
* Material: 0.8mm cold rolled steel for durability through the majority of chassis, 1.0mm cold rolled steel around the 4x HDD area
Â
* To optimize performance of your P180 the choice of your power supply is crucial. Antec strongly recommends choosing from our Phantom, NeoHE or TruePower series
Â
* Silicone grommets in the hard drive cages absorb vibrations and reduce noise
Â
* Built in washable air-filter
Â
* Dimensions: 54cm (H) x 20.5cm (W) x 50.7cm (D) or 21.3″(H) x 8.1″(W) x 19.9″(D)
