be quiet Dark Rock TF Top Flow Review
Performance and Testing
be quiet Dark Rock TF Review
The test set up consisted of the following
Intel i7 3960X [email protected] 1.1v (undervolted) 4.0GHz @ 1.25v 4.4GHz @ 1.35v 4.6GHz @ 1.45v Gigabyte X79 UD3 Corsair Vengeance LP Memory Corsair HX850 V2 Corsair Force GT 60GB Coolermaster Storm Trooper.
As usual we'll be testing our coolers at varying levels of overclock and increasing levels of voltage.  This in turn of course means increasing levels of heat which the coolers need to dissipate.  To begin with we start with the undervolted stock speed.  Why undervolted? well if you have things set on "Auto", you may well be using more volts than are actually required to run at the chosen frequency, for example our 3960s will run quite happily at just 1.1volts, solid as a rock, 24/7, and as such we use this as our starting point.
Continuity is very important in testing, and for this reason we keep as many of the potential variables as locked down as possible.  We will be using OCCT in Linpack X64, AVX compatible with all logical cores tested and 90% free memory utilised. The test is set up to run automatically with just a few clicks to set it going.  A 10 minute idle followed by 30 minutes of testing and a 5 minute cool down is the order of the day and brings the total test time per clock speed to 45 minutes.  So as to remove subjectivity in determining whether a CPU has failed, OCCT is set to stop the test and register a fail should the max temp exceed 80 degrees.  In testing we noted that if even just one of the cores exceeds 82 degrees OCCT halts the test and a fail is recorded.
Not a bad start for the TF, making an entrance just under the half way point in the standings, and on a par with the mahoosive Cooler Master V8 we looked at quite a while ago.  To be honest though, performance at this level isn't a great metric of how well a cooler will do when the volts start to rise.
Turning now to the 4GHz test we up the voltage to 1.25 volts, this is what is deemed normally as stock volts. Something we are always harping on about on the forums is AUTO does not mean stock volts, and normally if you overclocking with "auto" volts the motherboard will be upping the volts much more than needed if you were to do it manually. By whichever means it happens, upping the volts (especially from our 1.1v undervolt) does have a big impact on temps, with an average increase of 10-15 degrees seen in the results.
At the higher levels of heat generated by the increase in voltage required for the 4.0GHz overclock, fan performance, although still a factor becomes less critical, replaced instead by a coolers ability to conduct the heat up the heat pipes and more crucially the total surface area of the fins enabling convection to the atmosphere.  In the case of AIOs and water cooling the surface area of the radiator and the efficiency of the contact plate begin to play more of a factor.
Things are not so good now that the OC has increased and the volts have been upped a bit.  The TF is still ahead of quite a few other traditional air coolers though so perhaps our concerns over the lack of fin stack mass we misplaced.
We're our concerns over the small fin stack misplaced?  Nope.  The Dark Rock TF failed to make it past the 4.0GHz point.  We should add that we gave it three chances to pass, and even re seated it and tested two more times, just in case the 220WTDP figure was right, and we were wrong, but sadly it was destined to languish at the 4.0GHz mark.
«Prev 1 2 3 4 5 6 7 Next»
25-06-2015, 14:19:37
dwatterworth
It's a shame it performs poorly out of the box. Mainly due to the fans? I wonder how the single fan configuration performs, these down-draft coolers are great for height restricted HTPC / SFF builds.
I've got a NH-C14 that matches the NH-D14 nearly step for step on a 3960X workstation at work. Wouldn't the Be Quiet TF cooler look nice with some Noctua NF-A14's or NF-P14's strapped on there? I bet those temps would drop a tad too.
They should have followed Noctuas lead and put in some fin stack pass-throughs to allow easy access to the mounting kit.
https://www.facebook.com/photo.php?f...type=3&theaterQuote
25-06-2015, 14:30:54
cooperman
Well most of these top down units are not realy for ultamate oc'ing there more for the budget mobo's that dont have mosfet heatsinks such as a lot of the budget FM2/+ mobos that can overclock, but you will still see in the manufactures notes that a top down heat sink is recommended.Quote
25-06-2015, 15:39:33
dwatterworth
I'd say the price range of these places it out of the budget territory that something like the Zalman CNPS series or CM GeminII cover.Quote
