bequiet Dark Rock 3 Review
Up Close: Packaging and Contents
The Dark Rock 3 comes in the Sultry Black packaging we have come to expect from bequiet.  The exterior of the box lists technical specifications as well as giving images and graphics of the product within.
bequiet Dark Rock 3 Review     bequiet Dark Rock 3 Review
Opening up the lid reveals the Cooler nestled within.  Cut and shaped formed expanded foam packaging holds the Rock 3 very firmly indeed, with the small accessories box being isolated from it to prevent damage in transit.  The Cooler comes with the fan already attached and the whole shooting match can be lifted out of the box in one go.
Along with a fold out sheet of multi language instructions you also get a universal mounting plate, separate brackets for AMD and Intel, a handy dandy (Although in use slightly spazzy) spanner, a tube of TIM, shed loads of screws and an additional set of fan mount spring clips.
«Prev 1 2 3 4 5 6 Next»
25-06-2014, 16:33:56
roelst
Is it just me or are those fins on the baseplate mounted the wrong way? If they turned them 90 degrees, the fan would have more influence on those.
Anyway, it is a nice looking cooler!Quote
26-06-2014, 01:35:47
Yoda/Gaz
Love the look of the Be quiet Dark Rock 3 but wish they would sort out the poor mounting system :PQuote
26-06-2014, 02:35:13
demonking
temps don't look right on the 4.4 test.
pro3 has 67.7c with delta of 47.1c and rock3 67.3c with delta 47.3c but both have an ambient of 20c??????.
Am i missing something as that math dos not seem correct or is the rock3 actually outperforming its big bro?Quote
26-06-2014, 12:07:26
looz
Sorry for moaning but would it be possible to upload those charts in .PNG?
Surprisingly good results!Quote
26-06-2014, 12:36:17
Wraith
Very nice offering from Be Quiet! Quality review Gary.
Pros: Colour, nicely lapped base, fins have nice spacing, multi socket brackets, 6x heat pipes.
Cons: Only 1x set of fan mounts leaving out push pull option.Quote
