Bequiet Shadow Rock TopFlow Review
Up Close Packaging and accessories
Published: 26th March 2012 | Source: bequiet | Price: £39.99 |
The Shadow Rock TopFlow comes packaged in be quiets signature black box. In addition to giving images and graphical representation of the cooler inside the box also details special features and technical specifications. Inside the box the cooler comes securely held in place by shock absorbing expanded polystyrene. Accessories and instructions are presented in their own separate box.
The cooler comes complete with all the mounting brackets and assorted screws you'll need to mount to the compatible processors (listed on page 1). Also included is a good sized tube of Dow Coming thermal grease. Instructions are clear and easy to read with both "exploded" views of the whole assembly and zoomed in views of detail areas. The image below right is only an example of the entire instructions.
Overall dimensions without mounting material (L x W x H), (mm) 171 x 137 x 126'Quote
