beQuiet Silent Loop 360mm AIO Watercooling Review
There market isn’t exactly awash with 360mm AIOs, so when we heard that be quiet were adding a 360mm version into their silent loop range, we were determined to take a look. Â In simple terms, it appears to be a 360mm version of the silent loop 240 that we looked at in our AIO Mega test last year. Â The big question is though, will the extra real estate offered by the 360 give it the oomph to topple the current chart topping AIO
Technical Specification
Intel | Â LGA 775 / 1150 / 1151 / 1155 / 1156 / 1366 / 2011(-3) Square ILM / 2066 |
AMD | Â AM2() / AM3() / AM4 / FM1 / FM2() |
Rad Dimension | Â 397x124x55mm (LxWxD) |
Rad Material | Â Copper |
FPI | 15Â |
Cold Plate | Copper (Nickel Plated)Â |
Fans | 3x120mm Pure Wings 2 @ 2000rpm |
Noise | Â 36.9dB(A) |
Static Pressure | Â 2.23MMH2O |
Airflow | Â 65.51cfm |
Â
Â
