BitFenix Neos Review
Stripped
Published: 18th August 2014 | Source: BitFenix | Price: 29.99 |
Stripped
Stripping the Neos involves little more than tugging off the front panel. As the front I/O is attacehed to the chassis itself there are no concerns regarding pulling cables though. With the front removed we can see that although there are no fans fitted in the front of the case, the Neos can accept two 120mm fans and even has a removable clip on dust filter. Getting down to the bare chassis also confirms our thoughts that the Neos shares its origins with the Comrade. This isn't intended as a criticism, far from it, the sharing of a chassis between models is something that has gone on from the very beginning, and is one of the main ways kit manufacturers are able to keep costs down.
Turning to the front panel itself we get a better view of the fan intake and 5.25" drive area. This front panel is well build and well put together.
If you're a modder you've probably already noticed this, but just in case, we thought we'd draw your attention more particularly towards an interesting feature. What? you might ask. Well the entire front mesh panel and drive covers are held in place by simple bent tabs. What this means is that should the great variety of colours offered by BitFenix not suite you it would be the work of minutes to pop the front mesh off and re style it in a colour of your own choosing.
No link Guv? >>Review<<
Still a good little case though, it does the job
EDIT: completely understand Guv, reviews and preparing for i52 busy busy busy.Quote
