BitFenix Portal Review
Published: 2nd June 2017 | Source: BitFenix | Price: 119.99 |
It's been a while since BitFenix have released an M-ITX case as good as the all conquering Prodigy. Sure, there were a few variations on the theme, but for the greater part they all used pretty much the same chassis. As the chaps over at Betfenix have never been ones to rest on their Laurels, and perhaps with the need for a refresh in mind, they got busy with the old slide rule and have released the new Portal case. First impressions are good, the case is Aluminium over a steels chassis, with hardly a sniff of plastic to be found save for the acrylic window in the top from which we're assuming the Portal takes its name. We say assume, as strictly speaking a portal is an entrance or a gate, but can be devolved to mean a way of viewing into another realm. Also you can actually buy a Portal without the window, so that would make it a portal-less Portal. Anyways, best we stop rambling and have a look at the tech spec and see what lies beneath the stunning Aluminium skin.
Dimensions | 382x185x411mm (HxWxD) |
Material | Aluminium skin over Steel Chassis, Acrylic Window. |
Form Factor | M-ITX |
Colour | Black (White also Available) |
Weight | 5.81kg |
Front I/O | 2xUSB 3.0 HD Audio |
Expansion Slots | 2 |
Air Cooling | Front: 1x120mm Rear: 1x80mm |
Water Cooling | Front: 1x120mm |
3.5" | 2 |
2.5" | 3 (2 shared with 3.5) |
PSU | SFX or SFX-L (not supplied) |
Max GPU Length | 300mm |
Max CPU cooler Height | 125mm |
I can't wait to see portal turret themes case mods!
https://i.ytimg.com/vi/qdpvj_iVAFk/maxresdefault.jpgQuote
Glad you got one in and cheers as ever for the review.Quote
