Cooler Master Cosmos Infinity 30th Anniversary Limited Edition Case Preview
This is more than just a custom C700M
Cooler Master’s Cosmos Infinity 30th Anniversary Limited Edition chassis is designed to be something special, offering users a unique colour scheme, machined metallic components, etched glass, and a lot of other custom elements.
Below we can see the case’s chameleon effect handles, its ARGB lighting elements, and the case’s wealth of front-mounted I/O options. We can also see the case’s use of tempered glass panels that have curved/bent sections, a feature that is uncommon for PC cases. This chassis is clearly a Cooler Master Cosmos design, but it’s very different to anything that we have seen before. Â
Inside the enclosure we can see the case’s custom aluminium motherboard tray, which has a CPU cut-out that has the same shape as Cooler Master’s iconic logo. This logo and 30th anniversary branding is etched into the right hand side panel of the Cosmos Infinity, lining up with this CPU cut-out perfectly. Even the little details within the Cosmos Infinity are well thought out, and it is rare to see a case that has a motherboard tray with this kind of design. Â
At the rear of the Cosmos Infinity, we can see many CNC machined elements, all of which give this limited Edition case an industrial looks that is simply impossible with mass produced cases. These “armour plates”, give users something nice to look at though the case’s windowed side panel, and contain a machined 30th anniversary plate.Â
Within the Cooler Master Cosmos Infinity are RGB strips around the outside of the chassis, with the inside of the case being illuminated by the chassis’ ARGB fans. Â
Overall, the Cosmos Infinity has a very clean aesthetic, both internally and externally. This case has plenty of space for cable management, and lot of space for a custom liquid cooling setup for those who want to go down that route.Â
