Cooler Master Eisberg 240L Prestige Review
Up Close:  Packaging and Contents
The 240L Prestige comes packaged in an attractive Black and “Cooler Master Purple” box.  The exterior has shadowy images of the Eisberg along with features and specifications
Cooler Master Eisberg 240L Prestige Review     Cooler Master Eisberg 240L Prestige Review
Inside the Eisberg is wrapped in polythene and cossetted in egg box style cardboard.  As the Eisberg comes pre assembled the main unit is actually in one long sausage of a polythene bag making if quite hard to extract.  Also in the box are a pair of Cooler Master badged fans, a set of instructions and all necessary fixings.
When we reviewed the 120L we commented that the instructions were comedy small.  Well as Cooler Master have stuck with the same instructions we thought we’d show you just how small they are.  The picture below left is an exploded view of how the assembly goes together.  It’s about 15mm x 10mm, as are the other diagrams.  Real nose to the paper job to see what’s going on
Thankfully all the required screws and brackets come in their own packs and although not labelled it is relatively easy to work out which bits you need for which CPU.
Cooler Master Eisberg 240L Prestige Review     Cooler Master Eisberg 240L Prestige Review Â
