Cooler Master HAF Stacker System Review
HAF 945 Fully Stripped
Cooler Master have made the HAF system remarkably easy to strip down. Minimal use of rivets means that nearly all the major internal structures can be removed, and with cases across the range sharing identical screw hole layout said components can be re distributed so as to suite the builders needs
Â
Ok, so you will get more than a little familiar with your favourite screw driver (be honest, you do have a favourite don’t you), and you’d best get yourself a handy dandy pot to stop you losing all the screws, but we’d rather have it this way than any other. Had Cooler Master opted for rives we’d have been gutted.
Â
With everything off and piled up you get an excellent idea of just how modular this system is.  And if you’re the sort like us that just can’t help think about modding a case then knowing you can get I apart easily sure gets the juices flowing
