Cooler Master Nepton 240M Review
Up Close: The Radiator and Pump
Measuring 274mm from end to end the Nepton 240M is average size for a 240mm AIO,  At 27mm thick it's also neither particularly thick nor skinny in any especial way.  In fact, it's suspiciously almost identical in size to the Corsair H100i which measures 275mm long by 27mm deep.  Fin spacing is rather open, as you can see from the image below right where it's actually possible to see the tubing and cold head through the radiator.  The cowling has mounting holes on both sides for a pair of 120mm fans, enabling a push pull set up to be achieved if so desired.
Cooler Master Nepton 240M Review     Cooler Master Nepton 240M Review
The Nepton comes with its name printed neatly on the side of the Aluminium chamber, a touch we've not seen before, and one we quite like.  Attention to detail is good with the radiator arriving with almost no bent fins
The tubing is of the corrugated variety, and while this might not look as attractive as the rubber type hosing it does tend to resist kinking slightly better and exhibits equal levels of flexibility.
The tubing enters the pump cold plate assembly by means of two 90 degree junctions.  These junctions, although stiff to move can be swivelled quite considerably in either direction which will of course aid installation and further reduce kinking.
The Cooler Master Logo is depicted on top of the contact plate.  The logo lights up white, but unlike other manufacturers kit is not RGB controllable.  Still, at least the contact plate is large enough to enable the 240M to be mounted effectively on even the biggest CPUs out there.
«Prev 1 2 3 4 5 6 7 Next»
15-01-2015, 07:58:27
Excalabur50
What a poor showing from Cooler Master just showing how unmasterful this cooler isQuote
15-01-2015, 08:00:20
barnsley
The 280L was such a beast. Quite why this is awful really is a surprise.Quote
15-01-2015, 14:14:03
Wraith
Wow I didn't expect that, who am I kidding it's a CM "M" series AIO, they all suck, of cause they will later release a "V" version and temporarily redeem their honor then follow it up with another "L" this seems to be the case time and again for CM. This was painful to see especially as it gets a whooping from a Air cooler, OK it's the D15 but still a 240mm AIO being out classed by air. Poor show Cooler Master.Quote
15-01-2015, 14:17:17
barnsley
Quite a few 240 AIOs are on par with the D15. Its a beast.Quote
15-01-2015, 14:20:40
IliaLo
I've watched some reviews of the 240M and I was looking for one to buy (based on the reviews I watched ), I guess it's good, I didn't find one, so I went with the 100i.Quote
