Cooler Master Nepton 240M Review
Assembly
Assembly
The Nepton 240M comes with a rather nice rubber gasket that should serve not only to reduce noise vibration harshness tansmission, but also reduce loss of static pressure as a result of air leakage around the fan cowling.
Cooler Master Nepton 240M Review     Cooler Master Nepton 240M Review
Cooler Master supply a range of knurled head screws, with longer ones included to enable the fans to be secured to the radiator while passing through the thickness of a case material.  Shorter screws are also supplied for use in mounting the radiator directly to the case with the fans attached on the opposite side as we have here.  With a Gunmetal finish to them the screws really do look the part.
Before the cold plate can be inserted into the case and attached tot he CPU it is necessary to attach the requisite AMD or Intel Mounting hardware.  These simply screw to the sides of the coldplate.
«Prev 1 2 3 4 5 6 7 Next»
15-01-2015, 07:58:27
Excalabur50
What a poor showing from Cooler Master just showing how unmasterful this cooler isQuote
15-01-2015, 08:00:20
barnsley
The 280L was such a beast. Quite why this is awful really is a surprise.Quote
15-01-2015, 14:14:03
Wraith
Wow I didn't expect that, who am I kidding it's a CM "M" series AIO, they all suck, of cause they will later release a "V" version and temporarily redeem their honor then follow it up with another "L" this seems to be the case time and again for CM. This was painful to see especially as it gets a whooping from a Air cooler, OK it's the D15 but still a 240mm AIO being out classed by air. Poor show Cooler Master.Quote
15-01-2015, 14:17:17
barnsley
Quite a few 240 AIOs are on par with the D15. Its a beast.Quote
15-01-2015, 14:20:40
IliaLo
I've watched some reviews of the 240M and I was looking for one to buy (based on the reviews I watched ), I guess it's good, I didn't find one, so I went with the 100i.Quote
