CoolerMaster MasterAir MA410M Review
Up Close: The Cooler
Published: 24th May 2018 | Source: CoolerMaster | Price: |
The Cooler measures 111.8 x 130.9 x 165.1 mm so should fit in most small to medium sized cases. It comes with a pair of clear bladed fans, with one on push, and the other on pull.
Although the MA410M is capable of some fantastic light shows, it's important to note that the fans themselves aren't actually LED, never mind RGB. Now, don't go letting this put you off, as the way CM have organised things they look just fantastic when the cooler itself does its RGB "thang"
CM claim that the vents in the side are to aid the exhaust of hot air and prevent the build up of hot spots in the cooler.
The Cooler has a one piece plastic top and side plate, which wraps round the Aluminium fin stack. There's also a clear covered view port into the top of the stack, which, once the RGB comes to life looks simply fantastic.
