CoolerMaster MasterAir Pro 4 Review
Despite what you hard core AIO loving bunch of ladies might think, there's still a very large percentage of overall cooler sales that go to traditional tower CPU coolers.  If there wasn't, then why would manufacturers such as CoolerMaster continue to bring new products to market?  As you might have guessed, the MasterAir Pro 4 is one of these new coolers.  Will it bring anything new to the party to lift it above the others, or will it simply be another option to choose from?  Best we put it through its paces and find out, starting as always, with the Technical Specification
Dimensions84x129x158mm (LxWxH)
Intel2011-v3, 2001, 1366, 1156, 1155, 1151, 1150, 775
AMDAM4*, AM3+, AM3, AM2+, AM2, FM2+, FM2, FM1
Heat Pipes4x6mm Copper
Fins56 x Aluminium (with top plate)
Fans1x120mm (option for additional 120mm)
Fan Speed650-2000RPM
Fan Airflow66.7CCFM
Fan Air Pressure2.34mmH2O
Noise30dB(A)
*AMD AM4 Upgrade kit needed.
«Prev 1 2 3 4 5 6 7 8 Next»
10-04-2017, 10:50:34
Doomslayer
IMO never understood why you would want to put one of these cheaper CPU coolers on a socket 2011/V3 if you spending that much money on the X99 motherboard you should be going with an AIO or a higher end CPU cooler.Quote
10-04-2017, 18:45:00
warpuck
When a AIO clogs up you toss it. When a Noctua C/D 14 clogs up, remove fan and suck out the clog with brush and vacuum cleaner. The fan should last 5 years or more. So the only thing that is left with a AIO is the fans. DIY water has got to be cleaned and drained if you use flexible tubing annually. Rigid maybe once every 3-5 years drained and cleaned. You still have to clean the dust out of the radiators 1 or 2 twice a year. They can both be moved to another socket style. I have had three different water cooler set ups and will not be using water again. A Noctua C or D 14 is almost as good as 240mm AIO and better than most if not all 120mm AIOs. If your ambient is 40C water is better, But 30C or less no real advantage. Truth I don't get any more DAILY Ghz out of a FX-8350 with water than I do with a C14Quote
10-04-2017, 19:17:47
NeverBackDown
Ever use a AIO?
I've used one virtually 24/7 for nearly what 2 years now? Never had a hiccup. This is an older 2nd gen AIO. Still going strong. The newer ones are even more robust. Really they will last as long as fans will.Quote
14-04-2017, 15:37:37
warpuck
Used a AIO 24/7 folding with a OCed FX-8350 (4.7Ghz). (200 watts +) 24/7 operation broke down the coolant corrosion inhibitors and it clogged up after about 1 year of that kind of abuse. A premium Noctua does almost as well as a AIO and it can be cleaned with small paint brush and a vacuum cleaner. A AIO is sent back if it is under warranty. Performing surgery on it is tedious, if it is out of warranty, plus it may not work again anyway. Considering that a Coolermaster 120mm x 40mm cost almost the same as Noctua 14 at the time? Water does cool better but it does have one more working part to fail and pumps will fail. I have 2 dead pumps now. Vapor condensation cycle has no moving parts, fans are plentiful and cheap enough to keep a spare around while you wait 50,000 hours for it to fail. I still have the Coolermaster fan that came with the AIO in use as a case fan. The 8350 is still happy folding @4.6 Ghz cooled by a Noctua NH-C14S with its companion GTX 690. Both cooling items have been discontinued. Only one still works. I have come to the conclusion that water is great if your system is only used for a few hours a day to squeeze the max out of your system.Quote
