CoolerMaster MasterCase 5 and Pro 5 Review
Up Close: Exterior
CoolerMaster MasterCase 5 Review
Up Close:  Exterior
Although the MasterCase 5 appears to pull its design cues from a number of sources, we do still like the individuality of the end result.  The handles on the top which may whisper Prodigy and Mac Pro look stylish and are fully weight bearing as they are reinforced with a metal frame internally.  This version of the case does not have a windowed side panel, lending a monolithic symmetry to the design.  Looking at the case, with it's carry handles we also can't help but be reminded of the Scout line of cases which for a while dominated the LAN party scene.
CoolerMaster MasterCase 5 Review     CoolerMaster MasterCase 5 Review
The front I/O panel, sporting a pair of USB3s, and the usual audio sockets, is bevelled at 45 degrees so is either on the roof, the front, or neither, depending on how you look at it.  We actually quite like the way CoolerMaster have done this as it offers the best of both worlds with regards to accessibility.
The top of the case has a large removable mesh panel.  As you can see, it's designed to accept a pair of both 120mm and 140mm fans.  in our opinion, with the rest of the case looking so sleek and minimalist, this rather utilitarian vent does rather spoil the aesthetic.
Anyone familiar with CoolerMaster cases will recognise that familiar Crysis hex mesh look to them.  What isn't immediately obvious is that there's a pair of 5.25" drive bay blanks positioned towards the top.  As we'll see later, this front panel and the mesh filter behind is easily removable.
The rear of the case is a pretty standard affair although the rear fan location is slotted for both 120 and 140mm fans.  A black bladed 140mm unit comes fitted in this position.  Below this we find seven vented PCI slot covers, with the lowermost offering a removable cable lock system for all your easy to nick peripherals.
The case rests on two large projections similar to those on the roof, further enforcing the previously mentioned styling cues.  Each of these has a pair of long rubber strips attached to it to aid stability and reduce transmitted vibration.  The underside of the case is otherwise smooth aside from the large PSU fan intake which does of course have a removable filter.
«Prev 1 2 3 4 5 6 7 8 9 10 Next»
18-08-2015, 04:47:55
King of Old Old School
Wow the 2nd case has got a 0, No need to remind people which case was the first one
Fail Cooler Master FailQuote
18-08-2015, 05:21:12
AlienALX
Remember kids, honesty is the best policy.Quote
18-08-2015, 06:23:13
Greenback
The problem being even if they add some of the suggestions Gary makes in the review, there are cases out already cheaper than the base case that have them. to me the base case should at least have room for an AIO in the roof considering that's where most people put itQuote
18-08-2015, 07:24:46
otis1337
Your conclusion is very difficult to read. It looks like a brick wall of text.
Try and break it down more with paragraphs.Quote
18-08-2015, 10:16:43
RickPlaysWarr
Thanks for the review Gary. When I first saw show pictures of this case, I thought it had possibilities. Sorry to see that the shortcomings have overwhelmed any possible positives the case might have had.
To me it seems like they tried to make a quality product but it fell victim to the "where can we cut a few cents off of the manufacturing cost" demon. I really wish they had just decided to put out a pro/premium product and followed through with that.
--Rick--Quote
