CoolerMaster MasterCase Maker 5 Review
Up Close: Exterior Continued
Published: 17th May 2016 | Source: CoolerMaster | Price: £179 |
The rear of the maker 5 is a standard ATX affair, with a 140mm fan mounted into slots, sitting above a ventilation panel are 7 vented PCI slot covers. Down at the bottom we find the PSU cut out with a mounting bracket that allows the PSU to be slid in from the rear.
The case stands sturdily on two metal bars with added rubber dampening. There's also a pull out dust filter under the PSU area.
Before leaving the exterior let's take a look at the flip side of the standard window pattern to show you something that's not immediately obvious. look closely and you'll see that it has a darker section towards the bottom which is intended to obscure the sub floor area from view. Look even more closely and you'll see that it's actually removable. Nice little detail CoolerMaster!
At least CoolerMaster is giving people options like the Front Panel which is a good idea wish more companies do it.Quote
Really like all the nice goodies included. The rad support is quite nice for the size of the case.
That extra 140 fan though
