CoolerMaster MasterCase Maker 5 Review
Up Close: Interior
CoolerMaster MasterCase Maker5 Review
Up Close:  Interior
The interior of the Maker 5 is on the whole very similar to the other cases in the line.  A good sized, in fact excellent sized CPU cut out dominates the upper left quadrant, with a neat row of grommeted management holes descending to its right.  Up near the roof line there are additional small un-grommet holes for passing through fan cables and the 8pin CPU cable
CoolerMaster MasterCase Maker5 Review     CoolerMaster MasterCase Maker5 Review
The maker 5 has a two bay 5.25" cage beneath which we see a rack for 3x3.5" drives.  Both these racks can be easily removed, with the maker 5 offering the ability to re site the 3.5" rack if required.  Under the sub floor there's an additional two bay 3.5" drive rack, this can also be removed or moved posteriorly to allow room for rads and additional fans in the front.
Towards the rear and above the sub floor there's a pair of 2.5" mounts.  These slide easily in from one end and are secured by a knurled thumb bolt at the other.  The PSU is located under the sub floor, and sits on a pair of padded rails.  Owing to the layout down here , there's basically no limit on PSU length.
Above the 7 vented PCI slots we see a 140mm fan.  If you choose to, you could swap this for a 120mm unit as mounts are provided.  We'll look more closely at the roof in the next few pages, but for now let's just take a peak up into it and wonder just how much rad space we have?
«Prev 1 2 3 4 5 6 7 8 9 Next»
17-05-2016, 07:45:26
WYP
Loving this case. I wonder what it would look like in white......Quote
17-05-2016, 07:54:36
King of Old Old School
IMO this is the second best case on the market first being Fractal.
At least CoolerMaster is giving people options like the Front Panel which is a good idea wish more companies do it.Quote
17-05-2016, 08:11:05
x blader
https://twitter.com/CoolerMaster/sta...57860613824512Quote
17-05-2016, 12:51:21
CreatiXx
do you get the 2 side panels when you buy the case or do you need the bigger one apart?Quote
18-05-2016, 01:32:14
Kushiro
If only the less were white.
Really like all the nice goodies included. The rad support is quite nice for the size of the case.
That extra 140 fan though Quote
