CoolerMaster MasterCase Maker 5 Review
Accessories
CoolerMaster MasterCase Maker5 Review
Accessories
The fact that we've never dedicated a whole page to accessories should tell you something about how many goodies you get with this case.  First up is the steel accessories box.  Yep, that's right, a small steel box to keep all your bits and bobs in.  But that's not all, this little box has a soft rubber pad on its base, so as not to mark and surfaces, and as if that wasn't enough, the base is also magnetic which means if you turn it over it makes a perfect tray for keeping all your screws safe from wandering off the edge of the table while you complete your build.
CoolerMaster MasterCase Maker5 Review     CoolerMaster MasterCase Maker5 Review
Inside the box we find all the screws we could ever need, along with a slack handful of cable ties, a brace of self adhesive cable management ties and brackets that can be added to the case after the 5.25" bays have been removed to allow the addition of an extra 140mm fan.
Remember that large glass panel door, well in another box you'll find the key and a rather posh looking cloth for keeping it free of your grubby finger prints.  Oh, and you also get an additional 140mm fan to mount in the front, should you so desire!
We quite like what CoolerMaster have done with the screw packs.  Although they're in one long string, the screws are all separated with each pod being clearly labeled with regards to its contents.  the instructions are big on pictures and small on words and open out in a very large banner.  They're ok, but could do with being a little more detailed.
«Prev 1 2 3 4 5 6 7 8 9 Next»
17-05-2016, 07:45:26
WYP
Loving this case. I wonder what it would look like in white......Quote
17-05-2016, 07:54:36
King of Old Old School
IMO this is the second best case on the market first being Fractal.
At least CoolerMaster is giving people options like the Front Panel which is a good idea wish more companies do it.Quote
17-05-2016, 08:11:05
x blader
https://twitter.com/CoolerMaster/sta...57860613824512Quote
17-05-2016, 12:51:21
CreatiXx
do you get the 2 side panels when you buy the case or do you need the bigger one apart?Quote
18-05-2016, 01:32:14
Kushiro
If only the less were white.
Really like all the nice goodies included. The rad support is quite nice for the size of the case.
That extra 140 fan though Quote
