CoolerMaster MasterLiquid ML240L RGB Review
Up Close: Radiator
CoolerMaster MasterLiquid ML240l RGB Review
Up Close:  Radiator
The Radiator measures 277x119.6x27mm (LxWxD), which makes it 52mm thick with standard 25mm thick fans.Aesthetically, it's nicely squared off, and has a a simple white CoolerMaster logo on each side.
The Rad has a find density of 21 fins per inch, and has a total of 12 visible water channels, which puts it towards the denser end of the scale.  This though shouldn't be a problem, as the fans it's partnered with are more than capable of pushing through the air required.  Our only real concern is at what price with regards to noise?
The Braided tubing is as flexible as it needs to be and showed no evidence of wanting to kink on installation.  The tubing is inserted into the rad via sealed unions, and for once it's nice to see the absence of the "Grannies Ankles" type fitting extolled by some manufacturers.
The pair of 2000rpm clear bladed RGB fans attach by means of chromed thumb bolts with cross head tops for tightening.  Each of the fans also have rubber isolation pads on each mounting surface.
«Prev 1 2 3 4 5 6 7 8 9 10 Next»
14-12-2017, 08:58:52
Digikid
Looks nice except for that outdated awful logo of theirs. They need a new one that is not so "in-your-face" and more subtle.Quote
18-01-2018, 07:31:13
SuB
does make me laugh with their product naming repetition "cooler master master liquid master liquid 240 L"Quote
18-01-2018, 19:08:56
NeverBackDown
Thought the same thing
Trying to say it 5x fast is entertainingQuote
