CoolerMaster MasterLiquid ML240L RGB Review
CoolerMaster MasterLiquid ML240l RGB Review
It’s fair to say that there are now a fair few AIOs on the market, with the 240mm Rad option being the sweet spot with regards to price and performance.  With this in mind it’s perhaps not unexpected for a manufacturer to do something to lift there product above the others.  Some manufacturers go for out right performance, some for low noise, and some for aesthetics, and other for software integration.  CoolerMaster though have gone that little bit further and produced an AIO that is fully RGB enabled, with both the fans and the cold plate able to display a variety of colours.  It even has a few tricks up its braided sleeves.  For a little more detail on what you get for your money, best we have a look at the Technical Specification
Model ML240L RGB
Intel Intel® LGA 2066 / 2011-v3 / 2011 / 1151 / 1150 / 1155 / 1156 / 1366 / 775 socket
AMD AMD® AM4 / AM3 / AM3 / AM2 / AM2 / FM2 / FM2 / FM1 socket
Rad Material Aluminium
Rad Dimensions 277×119.6x27mm (LxWxD)
Fan Speed 650-2000
Air flow 66.7CFM
Air Pressure 2.34mmH2O
Noise 6-30dB(A)
Â
