CoolerMaster Seidon 240V AIO Watercooling Review
Contents and Packaging.
The Seidon 240V comes in a nice simple box which has graphics and details of the product within, as well as extensive technical data listed on the exterior
Â
Inside we see that CoolerMaster have protected the contents with egg box card and individual plastic bags.
Â
As well as the rad and pump assembly you get a pair of 120mm Silencio fans, A set of instructions, a fan splitter, brackets for both Intel and AMD, and of course all the screws and fittings you’ll need. Â Although the 240V only comes with two fans, it can be set up with four in push pull, with CoolerMaster including an additional eight long screws to make this possible.
