CoolerMaster Silencio 352 Review
Â
With m-ATX and to some extent Mini-ITX motherboards becoming ever more powerful and as a result more popular and mainstream, it necessarily follows that the discerning PC enthusiast is going to be looking for an enclosure that best suits their needs. In recent months we’ve looked at both the original and the latest “Pure” version of the CoolerMaster Silencio 650 line up, and we’ve been well impressed with them. Although these cases will take an m-ATX case, they’re far from being small form factor. Enter then the Silencio 352, an SFF case with more than a few aces up it’s sleeve.Â
Â
Technical Specification
Model |
SIL-352M-KKN1 |
Available Colour |
Midnight Black |
Materials |
Polymer, Steel |
Dimensions (W x H x D) |
200 x 378 x 453mm / 7.8 x 14.9 x 17.8 inch |
Net Weight |
4.7 kg /Â 10.3 lbs |
M/B Type |
micro-ATX, Mini-ITX |
5.25″ Drive Bays |
1 (the max. length of ODD: 170mm / 6.7 inch) |
3.5″ Drive Bays |
3 (1 exposed, 2 hidden) |
2.5″ Drive Bays |
4 (hidden) |
I/O Panel |
USB 3.0 x 2, USB 2.0 x 1, Audio In & Out, SD Â card reader x 1 |
Expansion Slots |
4 |
Cooling System |
Top: 120x15mm fan x 1 (optional) |
Power Supply Type |
Standard ATX PS2 |
Maximum Compatibility |
VGA card length: 355mm / 14.0 inch |
Â
Features
- The 1st microATX case with noise cancelling foam lined front door and side panels from Cooler Master
- Matte front panel for an elegant look
- Two powerful XtraFlo fans in the front and rear for optimized airflow
- Liquid cooling ready for professionals and enthusiasts – supports a 240mm radiator in the front or a 120mm radiator in the rear
- Dual Super Speed USB 3.0Â & SD card reader
- Supports a CPU cooler up to 155mm / 6.1 inch tall and high-end graphics cards up to 355mm / 14.0 inch long
- Great expandability with the support of up to 4 SSDs and 3 HDDs
- Multiple dust filters (top, bottom, front) for improved system maintenance
Â
 Â
