Cooltek W2 Review
Interior: PSU and Storage side
Cooltek W2 Review
The extremely well fitting side panels are held on with push grips, meaning that the just a gentle tug sees them released.  Having looked at the motherboard side, it's now time to turn the case around and look at the reverse side.  Up in the top right hand corner there's a rack that's able to accept up to 3x3.5" drives.  Alternatively some of this storage can be sacrificed in order to mount an external 5.25" drive.
Cooltek W2 Review     Cooltek W2 Review
The full size ATX PSU is mounted on its side at the bottom of the case, resting on four good sized rubber isolation feet.  in the opposite corner we see the PCB supporting the front I/O connections all of which remain attached to the case when the side panel is removed.
The upper left corner has a small rack for up to 3x2.5" drives with a small grill above it sporting mounting holes for an 80mm fan.  A nice touch, and one that shows attention to detail is the presence of foam anti vibration linings around the entirety of all side panel contact points.
«Prev 1 2 3 4 5 6 7 8 Next»
06-01-2015, 10:15:40
Wraith
Nice write up Gary, what's not to like indeed. Love almost everything about this apart from the window, I know it's beveled but it sort of detracts from the overall sleekness, had it been flush with no visible screws I'd have said this case stinks of win.Quote
06-01-2015, 13:07:07
Saltire35
I agree with Wraithguard... the window panel is the only small niggle I have with the W2, apart from that I can't fault it.Quote
