Cooltek W2 Review
The Build
Cooltek W2 Review
The Build
With the PSU round the back the entirety of the left hand chamber is given over to Motherboard living quarters.  We've shown it here with our usual ATX rig, although it is capable of taking the slightly larger XL-ATX boards.  The grommeted cable routing holes are well placed given that things are very non standard and looking round the back there's more than enough room and cable tie points for even the most ham fisted of builders to make things look half decent.
Cooltek W2 Review     Cooltek W2 Review
The voluminous capacity of the rear area means that there's no problem losing any unwanted and unused cables.  Even if you were using aftermarket cable extensions on everything you'd still not have to worry about fitting it all in.
The rear of CPU area may seem obstructed by the HDD rack, but if you're struggling you can always whip the rack out to give you more elbow room.
With everything in there's plenty of room back here, so much so that we wonder if some of it could be better utilised, and in case you're wondering just how much cable management space there is, how does 95mm grab you.
«Prev 1 2 3 4 5 6 7 8 Next»
06-01-2015, 10:15:40
Wraith
Nice write up Gary, what's not to like indeed. Love almost everything about this apart from the window, I know it's beveled but it sort of detracts from the overall sleekness, had it been flush with no visible screws I'd have said this case stinks of win.Quote
06-01-2015, 13:07:07
Saltire35
I agree with Wraithguard... the window panel is the only small niggle I have with the W2, apart from that I can't fault it.Quote
