Corsair Graphite 380T Review
The Build Continued
With plenty of cable tie points about the place the most obvious place to route the cables was the roof area as this would largely leave them hidden from sight when the case is viewed from above through the acrylic windows. As usual we’ve used our ancient 8800GT however the 380T will actually take any dual slot GPU up to 290mm Cooling for the GPU is first rate as intake fans will be positioned right up against the mesh side panels.Â
Â
We think the whole lot goes together pretty well, with the curves of the case hugging the extent of the hardware within.
Â
Having remarked on how nice it would have been to have 280mm rad compatibility, looking at the pictures below we can’t help thinking how close the case comes to being able to offer room for two 240mm rads.
