Corsair H100i GTX Review
Assembly and Fitting
The pair of grey bladed high rpm fans are fitted my means of long cross head screws with unattached washers.  There are holes on each side of the rad so a push pull configuration is achievable, however only one set of eight long screws is provided.  With the fans at 25mm thick and the radiator at 30mm, the whole lot comes in at just 55mm thick, which means it should fir into the roof of quite a few cases.
Corsair H100i GTX Review     Corsair H100i GTX Review
We couldn't help but take a few arty farty shots to show off the beauty of the rad an cold plate.
Onto fitting then and the first job is to attach the mounting hardware.  We're screwing into the motherboard but otherwise you'll need to use the universal back plate.
«Prev 1 2 3 4 5 6 7 8 Next»
11-03-2015, 13:04:35
RickPlaysWarr
Nice review Tom. I don't think you are mental going on about the wires and hose connections. I wonder if its a price point that has to be met. I don't know why they change OEM manufacturers within the same product line. It also effects my OCD as it does yoursQuote
11-03-2015, 13:08:01
JR23
Who said CoolIT
I think your niggles with the cooler were well founded and wd for revealing that the grey trim can easily be removed. For a lot of people will not care about the cables even slightly and value the increased performance over the H100i so really Performance is the perfect award for it.
Corsair were silly with the USB placement and I would say it annoys me but I have become so anal I wouldn't plug it in wherever they placed it. Just set the LED colour in link one time and leave it on it's own after that. Similarly the criticism about not having push/pull support like the H100i is a bit of a weak point for it too. I also really don't like the fact you can't remove the fan cables should you wish to use motherboard headers or fixed voltage fans. I prefer the H105/Kelvin approach of just chucking a few splitters in the packet, but we all know how much Corsair are addicted to moar features. The hoses still look ridiculously long and fixing them is very odd.
I wouldn't go for it and i'm glad I swapped my H105 for a Kelvin rather than waiting for these.
JRQuote
11-03-2015, 13:16:10
tinytomlogan
Originally Posted by JR23 View Post
Who said CoolIT
JR
If you dont plug it in you cant control the pump YOU would need to faff about with this. After our debate the other day this at full chat isnt quiet at all. Compared to the H110i GT this thing is plain noisey and I honestly think its down to the Asetek OEMQuote
11-03-2015, 13:17:31
JR23
That's tragic then, H100i's were always happy without anything connected. That's a big step backwards.
JRQuote
11-03-2015, 13:22:22
Dark NighT
A nice review there, it looks quite good apart from that usb connection and a tiny little detail that you didnt pick up on which i think is important but utterly small.
http://i.imgur.com/prKpwkV.pngQuote
