Corsair H100i Pro AIO Cooler Review
Results
Published: 19th July 2018 | Source: Corsair | Price: |
Results
There is no denying the effectiveness of the H100i Pro at keeping our processor cool, nor has the hard work that Corsair have put in to tuning it for the quietest possible experience been in vain. This is a very quiet and very capable cooler. In fact if you're the type of person who likes a balanced profile we think that you might as well go for the quiet profile, such is the small delta difference and enjoyable silence.
Hi there! Used to be more active on here years ago, but I've kept watching your videos from time to time. This time I had to chime in with something
At around 9min 30sec (in the video review ofcourse) when you mentioned you wanted more options on the "GRAPHING" screen, I believe the "DASHBOARD" tab at the top of the software does exactly what you were asking for? The Dashboard tab is basically Corsair's replacement for using HWmonitor and such.. I remember setting it up for fun at one point, it was a bit tricky to set up, but it will definitely give you graphs for GPU/CPU/MOBO/RAM temps and fan speed! If I remember correctly you have to start with all graphs and remove what you don't want. |
It was more of I think that it should be easily accessible and then when selected it links the fan speeds to cpu core #1 for exampleQuote
Just interested though - is it really worth it? The cooling is at best on a par with the Noctua NH-D15 at 100% on the fans, and I'm guessing the fans on the air cooler are also at full tilt, too - how do they compare volume-wise?
When I'm doing a blender render or encoding or compiling a large project, I occasionally hear my computer - but given I can't do anything else when the machine is at full throttle anyway, I just go off and make a cup of tea and no longer hear it. Maybe it's just me but I don't get why someone would go for this instead of a good, quiet air cooler unless the cooling potential is significantly greater (is it? It doesn't seem that way from the graphs!).Quote
I've got an Noctua NH-D14 in a really fairly open Xigmatek mATX case. It's so quiet, I can barely tell when the machine is on. A mate got one of the Corsair H100-line (predecessor to this) and was astonished at how loud it was on pretty much every setting and several different fan makes on the rad, so I'm glad to see Corsair take noise seriously with this update.
Just interested though - is it really worth it? The cooling is at best on a par with the Noctua NH-D15 at 100% on the fans, and I'm guessing the fans on the air cooler are also at full tilt, too - how do they compare volume-wise? When I'm doing a blender render or encoding or compiling a large project, I occasionally hear my computer - but given I can't do anything else when the machine is at full throttle anyway, I just go off and make a cup of tea and no longer hear it. Maybe it's just me but I don't get why someone would go for this instead of a good, quiet air cooler unless the cooling potential is significantly greater (is it? It doesn't seem that way from the graphs!). |
I remember setting it up for fun at one point, it was a bit tricky to set up, but it will definitely give you graphs for GPU/CPU/MOBO/RAM temps and fan speed! If I remember correctly you have to start with all graphs and remove what you don't want.Quote
