Corsair H110i GT Review
Up Close: Packaging and Contents
The H110i GT comes in a sturdy black box, the exterior of which has images of the cooler as well as handy technical details and features of the product inside.
Corsair H110i GT Review     Corsair H110i GT Review
Opening the box up we're greeted with the now very familiar planet saving (and cost saving) egg box card insert, into which the cooler is nestled.  The cooler is further protected from knocks and scratches by a massive polyethylene bag.
The provided multi language instructions are comprehensive and cover the installation onto both AMD and Intel CPUs.  There's also a problem finding section at the back for when things don't go quite as planned.  Fittings seem a bit sparse but all the bases are covered here even if Corsair do leave you to sift through a single bag of fittings for the ones you want.
Also in the box are a pair of Corsair brushless fans.  The fans run at 2100rpm, outputting 113 CFM of air with a static pressure of 3.99mm H20 at a rated 43dB(A).  This High decibel reading that has us a little concerned.
«Prev 1 2 3 4 5 6 7 8 9 Next»
10-02-2015, 08:52:59
Tripp
yikes that stomped over everythingQuote
10-02-2015, 09:35:33
steverebo
Cheers Tom been waiting for this review.
The silver trims on the rad and block can be removed and replaced with a red or blue one.
http://i46.photobucket.com/albums/f1...psooffazri.pngQuote
10-02-2015, 09:44:05
Wraith
The king has returned! Corsair back to the top of the class Quote
10-02-2015, 11:27:07
TPC
That part from 30:15 on made me giggle @DicehunterQuote
10-02-2015, 11:50:01
JR23
Yes, i'm not sure I agree with everything but certainly i'm not going to hate on this at all. I did think the H100i pump block looked better and cleaner however I can appreciate this one is matt black which if it survives Corsair's packaging should stay looking fresh for a lot longer.
One thing, are the grey clips not replaceable? Why are you banging on about glue and hair dryers guv, I thought the idea was they just clipped off, is that GTX's only or something? Earlier in the day I was thinking to myself 'but it's gonna be upside down for some people' then I realized if they make it the wrong way up on the back when you swap them over it will be the right way around for everyone. Then watching the review it looked like they did exactly as I thought... but then you said glue. If they are infact permanent then I despise how poorly they fit around the octagonal part.
I can appreciate you must do A LOT of testing for these cooler reviews with multiple overclocks and multiple fan speeds all for an extended period of time. That must be time consuming. But I feel that it's a bit wasted when they aren't directly comparable from product to product.
By which i'm trying to say the Kelvin obviously has slow fans. If it had 2700RPM fans it would have humiliated everything ever but then you would have given it a shoddy award for being uber loud. Similarly the Nepton which is comparable size and product I have no idea how it 'actually' compares from the graph. ie. performance per db. I know it's not your style to analy measure noise levels and go nuts and I appreciate that because it's something the end user will never do either. But it would be great to have a result for every cooler at one fan speed and heat load. Not 12v or 7v! Just say 1500RPM. If it would be a total PITA to control each fan like that (it wouldn't you just need an Aquaero in the test rig) then maybe use the same fan every time. Just a directly comparable result at which the reader can sit back and think right at this noise level which is acceptable for me X cooler will perform the best.
JRQuote
