Corsair H115i PRO RGB and H150i PRO RGB Review
Published: 8th January 2018 | Source: Corsair | Price: TBC |
It's been a while since we looked at a Corsair cooler, and then what happens, two turn up at once, for today we're pleased to say that we have a sample of the brand spanking new H115i PRO RGB, and H150i PRO RGB AIO coolers to review. As you might guess from the nomenclature, these Coolers are both RGB enabled via the LINK software, which, as far as we can determine is capable of controlling all aspects of the pump and fans, if not every other item in the world! The big question though, is will they, as they say, still "cut the mustard" when it comes to performance, and being a triple fan 120mm rad and a dual fan 140mm rad, there's a good chance of them coming fairly high up the charts. For the time being though, let's have a gander at those all important Technical Specifications.
H115i PRO RGB
Model | H115i PRO RGB |
Intel | LGA 2066, 2011-3, 2011, 1366, 1156, 1155, 1150, 1151 |
AMD | AM2, AM3, AM4, FM1, FM2, |
Cold Plate Material | Copper |
Radiator Material | Aluminium |
Radiator Dimensions | 315x143x29mm (LxWxD) |
Fans | 2x140mm ML Series @ 1200RPM |
Fan Airflow | 55.4CFM |
Fan Static Pressure | 1.27mmH2O |
Fan Noise level | 20.4dB(A) |
The AMD sTR4 bracket will be available as an optional accessory in Q1 2018, available direct from CORSAIR
H150i PRO RGB
Model | H150i PRO RGB |
Radiator Dimensions | 396x120x27mm (LxWxD) |
Fans | 3x120mm ML Series @ 1600RPM |
Fan Airflow | 47.3CFM |
Fan Static Pressure | 1.78mmH2O |
Fan Noise level | 25dB(A) |
Nice to see another 360 AIO too.Quote
Damn, that performs incredibly well. I thought we were hitting the limits of AIOs, but those numbers are highly impressive. Other reviews aren't so favourable, but still good numbers.
