Corsair H80i GT Review
Assembly and Corsair link Software
Assembly
As with most AIO installs the first step is to attach the stand offs to the motherboard.  If you're using anything other than 2011 and the like you'll need to use the supplied back plate.
Corsair H80i GT Review     Corsair H80i GT Review
Attaching the rad and fans to the rear of the case is a bit of a fiddle and best carried out with the case laid on it's side.  Eventually though you'll get the holes in the case, fan and rad to line up so you can get the screws through.  The cold plate assembly is screwed down via the appropriate mounting bracket.
The tubing although quite rigid is flexible enough to make the curves between the rad and the contact plate look smooth and elegant without any hint of kinking.  In practice it would appear that the lack of 90 degree rotation fittings on the cold plate has had little effect of ease of fitting or tube routing.
The Corsair link Software
The Corsair link Software can be downloaded from the Corsair website and enables control of the fans, Pump and RGB lighting aspects of the H80i GT.  It also offers the ability to monitor a vast amount of activity and temperatures of other case components.  In the images below we've shown how the RGB illumination of the Cold plate can be controlled via three sliders enabling the user to choose any colour they wish.  It's also possible to add lighting effects should you so desire.  The image below right shows how the monitoring and control icons can be un-docked from the left hand column and placed into the representation of a case in the places you would expect to see them, or any where you want to put them for that matter.  This image also shows one of the ways in which the fan speed information can be displayed.
Corsair H110i GT Review     Corsair H110i GT Review
If you're not happy with the image of the case that opens when you boot the software, don't worry as Corsair bundle a whole host of other Corsair case images for you to choose from.  If you're not using a corsair case then fret not as you can actually up load any case image you choose, or presumably any image at all as we doubt the software knows what's there.  eCookie for naming the two cases shown.
In the image below left we've shown a little of how it's possible to set up a temperature sensor including the ability of the software to shut the PC down under certain parameters, and even send you and e-mail if limits you have defined are exceeded.  Below right we've shown how it's possible to define your own custom cooling profiles, allowing fan speeds to increase as thermal parameters are reached.  This custom profile is in addition to a whole host of pre defined profiles such as the performance, balanced and Quiet that we have used for testing.
Although eminently flexible with regards to set up and configuration,  the interface isn't exactly the most colourful or inspiring in the world.  You can though change from a dark back ground to a light one and choose what colour of text you would like
Having shown you the software that powers the RGB control of the cold plate we thought we'd show you some of the lighting effects.  We've got the intensity level set about half with the house lights off so as to show just the logo itself illuminated.
With the intensity cranked up it's also possible to have some light bleed into the edges of the bevelled silver area to give a back lit illumination effect to the plate.
«Prev 1 2 3 4 5 6 7 Next»
09-03-2015, 13:10:36
Wraith
Nice review Gary, I'm surprised by the graphs, it only out performs the original H80i on the MAX settings which as I already know is just not an option to the eardrums.. why such a drop in overall performance over it's predecessor. It really does look the part though with the grey corsair rad and block accents and that hose braid is gorgeous, just a shame it falls behind the H80i in the comfortable Quiet/Ballanced modes.Quote
09-03-2015, 18:54:27
Excalabur50
I don't know what is happening at house Corsair but some of their stuff is going backwards they need to turn it around before they lose their reputationQuote
