Corsair H80i GT Review
Performance and Testing
The test set up consisted of the following
Intel i7 3960X [email protected] 1.1v (undervolted) 4.0GHz @ 1.25v 4.4GHz @ 1.35v 4.6GHz @ 1.45v Gigabyte X79 UD3 Corsair Vengeance LP Memory Corsair HX850 V2 Corsair Force GT 60GB Coolermaster Storm Trooper.
As usual we'll be testing our coolers at varying  levels of overclock and increasing levels of voltage.  this in turn of course means increasing levels of heat which the coolers need to dissipate.  To begin with we start with the undervolted stock speed.  Why undervolted? well if you have things set on "Auto", you may well be using more volts than are actually required to run at the chosen frequency, for example our 3960s will run quite happily at just 1.1volts, solid as a rock, 24/7, and as such we use this as our starting point.
Continuity is very important in testing, and for this reason we keep as many of the potential variables as locked down as possible.  We will be using OCCT in Linpack X64, AVX compatible with all logical cores tested and 90% free memory utilised. The test is set up to run automatically with just a few clicks to set it going.  A 10 minute idle followed by 30 minutes of testing and a 5 minute cool down is the order of the day and brings the total test time per clock speed to 45 minutes.  So as to remove subjectivity in determining whether a CPU has failed, OCCT is set to stop the test and register a fail should the max temp exceed 80 degrees.  In testing we noted that if even just one of the cores exceeds 82 degrees OCCT halts the test and a fail is recorded.
Well it has to be said this isn't a brilliant start for the H80i GT.  let's hope it does better as the heat increases.
Turning now to the 4GHz test we up the voltage to 1.25 volts, this is what is deemed normally as stock volts. Something we are always harping on about on the forums is AUTO does not mean stock volts, and normally if you overclocking with "auto" volts the motherboard will be upping the volts much more than needed if you were to do it manually. By whichever means it happens, upping the volts (especially from our 1.1v undervolt) does have a big impact on temps, with an average increase of 10-15 degrees seen in the results.
At the higher levels of heat generated by the increase in voltage required for the 4.0GHz overclock, fan performance, although still a factor becomes less critical, replaced instead by a coolers ability to conduct the heat up the heat pipes and more crucially the total surface area of the fins enabling convection to the atmosphere.  In the case of AIOs and water cooling the surface area of the radiator and the efficiency of the contact plate begin to play more of a factor.
The H80i GT has recovered a bit at the max settings, but those balanced and Silent fan speeds leave it well down the charts
Upping the volts still further we achieve a stable 4.4GHz overclock at 1.35 Volts. It's here we start to separate the wheat from the chaff, with lesser coolers not able to disperse the increased heat effectively.
Again the H80i GT is doing well with the fans at full tatt but no so well when things are slowed down to more bearable levels
Finally our 4.6GHz test. Don't be fooled, this is an extreme test and the graph reflects this, you will only see the very best featured in this graph.
If we really want to measure outright performance, this is where we do it.
The H80i GT does make it into the hallowed halls of the 4.6GHz club, and is in fact the highest scoring 120mm rad based cooler in this chart.
«Prev 1 2 3 4 5 6 7 Next»
09-03-2015, 13:10:36
Wraith
Nice review Gary, I'm surprised by the graphs, it only out performs the original H80i on the MAX settings which as I already know is just not an option to the eardrums.. why such a drop in overall performance over it's predecessor. It really does look the part though with the grey corsair rad and block accents and that hose braid is gorgeous, just a shame it falls behind the H80i in the comfortable Quiet/Ballanced modes.Quote
09-03-2015, 18:54:27
Excalabur50
I don't know what is happening at house Corsair but some of their stuff is going backwards they need to turn it around before they lose their reputationQuote
