Corsair ICue 7000X RGB Case and H170i Elite Capellix Review
Published: 29th June 2021 | Source: Corsair | Price: |
Along with power supplies the CPU cooling you use, and definitely the case into which everything is installed, tend to be the parts of your case that survive the longest. We upgrade our GPUs all the time, CPUs now and again, motherboards rarely, but cases could've been designed for IDE hard drives and we still cling to them. This is particularly true if you've expended any energy at all on customising it to your taste.
Having not long looked at the Corsair 5000X case and H150i Capellix cooler, we know that many of you were thinking, "Cool, but can we have an even beefier cooling solution and larger case?", to which the Corsair answer is yes.
The H170i Elite Capellix is a triple 140mm AIO. If that doesn't already get your juices flowing we don't know what will. Modern CPU core counts are rapidly climbing to the stratosphere and need all the cooling you can muster to keep things under control, which means that the introduction of an even larger model to the wildly successful Corsair AIO range makes perfect sense. Not everyone owns a case which can support a gignormous 420mm radiator in the roof, indeed few do, so it also makes sense that Corsair have expanded their case range with the premium iCUE 7000X RGB. It's big, it's bold, it has enough room to easily fit the new H170i Elite Capellix in it.
With our test setup on hand and a fistful of fans, let's cast our eye over this new Corsair pairing and run some tests to see how well it performs. Ready?
iCUE 7000X RGB
Untill this day it baffles me that basically one of the absolute biggest companies in the industry, Corsair, haven't simplified their RGB solution.
I mean, just 6 cables alone for those 3 fans... Those going to something else that requires both power and data cable, so that's another 2 cables. And this is not even beginning to talk about the potential case fans that might be needed to be hooked up as well. Like come on, it's 2021, not 2001... |
-Replace the plexi with tempered glass
-Make the bottom of the case plain mesh with fan mounts
-Give both side panels captive thumbscrews.
-Make dust filters for all intakes easily removable.
-Update the cases IO with USBC.
-No rubberised surfaces, Just a nice matte black textured plastic.
I know we got the 740 and later the 680X but both were half assed products.Quote
Does absolutely nothing for me, I really wish they would just refresh the Air 540 and put some actual effort into it -
-Replace the plexi with tempered glass -Make the bottom of the case plain mesh with fan mounts -Give both side panels captive thumbscrews. -Make dust filters for all intakes easily removable. -Update the cases IO with USBC. -No rubberised surfaces, Just a nice matte black textured plastic. I know we got the 740 and later the 680X but both were half assed products. |
Im almost tempted to drop back to the 540 and sell the 1000D just for extra space
Its interesting that the 540 is still sold regularly here, but the 740 appears discontinued.Quote
I still have the 540. Didnt think much of the 740. Seemed quite hideous to me.
Im almost tempted to drop back to the 540 and sell the 1000D just for extra space ![]() Its interesting that the 540 is still sold regularly here, but the 740 appears discontinued. |
The supposed high end successor, The 680X from 2019, Needed a few areas changing and it would have been a proper successor but of course they had to follow the idiot trend of sticking glass infront of and on top of everything, Blocking airflow.
If they replaced the front and top glass panels with meshed up panels it would have been miles better, I replaced the top and front with plexi panels that are honeycombed from ColdZero, Not only did this drop internal temps by 2-3'c but also made the case quieter as it meant the fans didn't have to spin as fast trying to suck air from behind a solid glass panel.
Also having it so you need to practically dismantle your build to just clean the front dust filter is beyond stupid.
I don't know who the case designer at Corsair is but he needs to be moved to a different department, He's no good.Quote
Like come on, it's 2021, not 2001...Quote
