Corsair ICue 7000X RGB Case and H170i Elite Capellix Review
Up Close
Published: 29th June 2021 | Source: Corsair | Price: |
Up Close
With three 140mm fans on board the H170i Elite Capellix is physically bigger than its H150i sibling, but it's not until you have the box in front of you that you realise quite how much bigger it is. This thing is huge. We've set it aside for when the floods come.
When you look at it without anything nearby to have as a size context it's tough to fully appreciate how beefy the new H170i is, but if that CPU pump/block looks smaller than usual it might be a clue as to the dimensions of the radiator.
The CORE version of the Corsair Commander is present and correct, helping you keep a close eye on the fan speeds and lighting without having to spend yet more cash on a way to tie them all together.
Here are the three 140mm RGB SP fans. Hopefully a good combination between airflow and noise, something that all fans aspire towards. Normally Corsair fans hit the sweet spot but we'll find out soon enough.
Moving on to the iCUE 7000X case and the Capillex in "built up" format there is certainly plenty of space on the front to show off your choice of lighting.
If you like your cases with as little as possible covering up your hardware then the 7000X should be right up your street. Not only is there a big window at the front but the side window surround barely covers the case structure, let alone anything inside it.
If you like to tuck things away behind covers then the Corsair iCUE 7000X has you, ahem, covered. To the side of the motherboard is a panel which covers up the side grommets through which you stick your SATA cables and 24pin ATX cable, whilst the PSU and drives have their own cover. What's that? You want to get a closer look? Read on.
Untill this day it baffles me that basically one of the absolute biggest companies in the industry, Corsair, haven't simplified their RGB solution.
I mean, just 6 cables alone for those 3 fans... Those going to something else that requires both power and data cable, so that's another 2 cables. And this is not even beginning to talk about the potential case fans that might be needed to be hooked up as well. Like come on, it's 2021, not 2001... |
-Replace the plexi with tempered glass
-Make the bottom of the case plain mesh with fan mounts
-Give both side panels captive thumbscrews.
-Make dust filters for all intakes easily removable.
-Update the cases IO with USBC.
-No rubberised surfaces, Just a nice matte black textured plastic.
I know we got the 740 and later the 680X but both were half assed products.Quote
Does absolutely nothing for me, I really wish they would just refresh the Air 540 and put some actual effort into it -
-Replace the plexi with tempered glass -Make the bottom of the case plain mesh with fan mounts -Give both side panels captive thumbscrews. -Make dust filters for all intakes easily removable. -Update the cases IO with USBC. -No rubberised surfaces, Just a nice matte black textured plastic. I know we got the 740 and later the 680X but both were half assed products. |
Im almost tempted to drop back to the 540 and sell the 1000D just for extra space
Its interesting that the 540 is still sold regularly here, but the 740 appears discontinued.Quote
I still have the 540. Didnt think much of the 740. Seemed quite hideous to me.
Im almost tempted to drop back to the 540 and sell the 1000D just for extra space ![]() Its interesting that the 540 is still sold regularly here, but the 740 appears discontinued. |
The supposed high end successor, The 680X from 2019, Needed a few areas changing and it would have been a proper successor but of course they had to follow the idiot trend of sticking glass infront of and on top of everything, Blocking airflow.
If they replaced the front and top glass panels with meshed up panels it would have been miles better, I replaced the top and front with plexi panels that are honeycombed from ColdZero, Not only did this drop internal temps by 2-3'c but also made the case quieter as it meant the fans didn't have to spin as fast trying to suck air from behind a solid glass panel.
Also having it so you need to practically dismantle your build to just clean the front dust filter is beyond stupid.
I don't know who the case designer at Corsair is but he needs to be moved to a different department, He's no good.Quote
Like come on, it's 2021, not 2001...Quote
