Cougar Dark Blader G Review
When we first looked at the Cougar website, our initial thoughts were along the lines of ‘cheap plastic cases’, ‘style over substance’, ‘sharp edges’ and ‘will break easily’.  If we’re even more honest, when we first saw the box, we did a double-take because we honestly thought it said ‘Dark Bladder’ which unfortunately stimulated some deep adolescent ‘Black Adder’ double-entendre.  Teenage giggles aside, when we actually started digging down into the substance of the Blader, we were more than pleasantly surprised.  So if you’re looking for a nearly full glass ‘show off’ case, that retains excellent cooling and hardware credentials we recommend you read on.
Technical Specification
Dimensions  232x523x518 (WxHxD)
Material  Steel Chassis, Tempered glass panels, Brushed Aluminium
Weight
Motherboard  M-ATX, M-ITX ATX,CEB **E-ATX
5.25″  0
3.5″  4
Dedicated 2.5″  4
Front I/O  USB 3.0 x 2 / Mic x1 / Audio x1 / RGB Control Button x1
Expansion Slots  8 2 vertical
Air Cooling
 Front: 3x140mm/120mm
 Roof:  2x140mm/3x120mm
 Rear: 1×120 installed
Water Cooling
 Front:  *360mm or 280mm
 Roof:   *360mm or 280mm
 Rear: 1x120mm
Max CPU Cooler Height  170mm
Max GPU Length  380mm
Max PSU Length  200mm
**Requires Removal of cable bar
* Choose either of front or top to install a 360mm radiator
Â
