Cougar Dark Blader G Review
When we first looked at the Cougar website, our initial thoughts were along the lines of ‘cheap plastic cases’, ‘style over substance’, ‘sharp edges’ and ‘will break easily’. If we’re even more honest, when we first saw the box, we did a double-take because we honestly thought it said ‘Dark Bladder’ which unfortunately stimulated some deep adolescent ‘Black Adder’ double-entendre. Teenage giggles aside, when we actually started digging down into the substance of the Blader, we were more than pleasantly surprised. So if you’re looking for a nearly full glass ‘show off’ case, that retains excellent cooling and hardware credentials we recommend you read on.
Â
Technical Specification
Dimensions | Â 232x523x518 (WxHxD) |
Material | Â Steel Chassis, Tempered glass panels, Brushed Aluminium |
Weight |
Motherboard | Â M-ATX, M-ITX ATX,CEB **E-ATX |
5.25″ | Â 0 |
3.5″ | Â 4 |
Dedicated 2.5″ | Â 4 |
Front I/O | Â USB 3.0 x 2 / Mic x1 / Audio x1 / RGB Control Button x1 |
Expansion Slots | Â 8 2 vertical |
Air Cooling |
 Front: 3x140mm/120mm  Roof: 2x140mm/3x120mm  Rear: 1×120 installed |
Water Cooling |
 Front: *360mm or 280mm  Roof:  *360mm or 280mm  Rear: 1x120mm |
Max CPU Cooler Height | Â 170mm |
Max GPU Length |  380mm |
Max PSU Length |  200mm |
Â
**Requires Removal of cable bar
* Choose either of front or top to install a 360mm radiator
Â
Â
