CPU Air Cooler Mega Test
bequiet Dark Rock3
bequiet Dark Rock3
Price:  £51.17
Technical Specification
Dimensions160x137x97mm (HxWxD)
CPUIntel: 1150, 1151, 1155, 1156, 775, 1366, 2011/v3.  AMD:  754, 939, 940, FM1, FM2/+, AM2/+, AM3/+
Heat pipes6x6mm copper pipes
Fins51
MaterialsAluminium fins, copper base
Fan Speed135mm @ 1400rpm
Noise LevelMax 21.1dB(A)
Air Flow67.8CFM
Air Pressure2.1mmH2O
Weight976g
Up Close
We thought we'd pop in a shot of the instructions.  now don't go enlarging that image, what you see before you is pretty much the size of the actual diagrams you have at your disposal.  They are, needless to says pretty much useless.
CPU Air Cooler Mega Test     CPU Air Cooler Mega Test
The cooler itself is elegant in the extreme, you really do have to admit that bequiet make a damn fine looking cooler.  At 160mm tall case compatibility is good, and with a 135mm fan it should be a decent performer.
The heat pipes are Dark Nickel coated and run up through the 51 element "wave contour" fin stack.  The pipes are split into two rows on each side, with one slightly more medial than the other.
The top of the cooler is adorned with a stepped black brushed Aluminium cover plate, with gloss black caps for the heat pie ends.  Underneath, the 6x6mm dark Nickel coated heat pipes are a thing of beauty, with no evidence of solder splatter, it's all very clean and high quality down here.
Having learnt our lessons with the Rock2, fitting the Rock3 was a lot easier.  That said, even with the knowledge of how to do it correctly, the instructions still aren't wonderfully clear.  Unfortunately, considering this is a hefty 140mm fan based cooler with 6x6mm heat pipes it totally fails to perform.  Not quite bottom of the charts, but nowhere near where it should be when you add up the ingredients.  Again we think this lackluster performance is a product of the large fin stack coupled with a quiet low speed fan that just can't push enough air through. The fan is very quiet but then all of the other brands can easily have the fan slowed down, the bequiet combination is good to look at and quiet if thats what you are after but we cant help feeling like its over priced.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 Next»
10-08-2016, 14:32:21
shambles1980
Had a quick look..
dont see any AIO's in there as a comparison.. I think it would have been nice to see atleast 1-2 of the most popular ones in there, it would just round out the comparisons a bit better imo if you also factor noise efficiency and redundancy.Quote
10-08-2016, 14:36:41
PixxHD
Great article, good to see my D15 is still a beast in the air cooled department.
One small thing, while reading the D15 page I couldn't help but notice something wrong.
With the front fan installed you are though limited to standard height RAM.
This is actually not the case, the fan can be positioned forward due to the design of the mounting which allows for big RAM if you have the case clearance for the fan to protrude off the cooler.Quote
10-08-2016, 14:52:00
Spiderz
That explains all the hype around the Cryorig lot, good prices and performance there. Great to see so many all together in one place for comparison.Quote
10-08-2016, 14:53:46
Helix
The BeQuiet coolers are meant to be tightened from the back of the motherboard, not above and between the fins. No wonder you found it hard to do.. If you are saying that poor fitting is the reason they don't perform well, then the test results are not representative of the coolers performance.Quote
10-08-2016, 15:08:21
The_Governour
I bought the Be Quiet Dark Rock TF for the looks for the Lian Li Q10 build - was supriced that it placed so low.
Have the Raijintek Pallas on my living room rig cooling a G3258 and I thought it was great.Quote
