CPU Air Cooler Mega Test
be quiet Dark Rock Pro3
Price:  £61.98
Technical Specification
Dimensions163x137x150mm (HxWxD)
CPUIntel: 1150, 1151, 1155, 1156, 775, 1366, 2011/v3.  AMD: 754,939,940, FM1, FM2/+, AM2/+, AM3/+
Heat pipes7x6mm copper pipes
FinsTwo stacks of 45 each
MaterialsAluminium fins, copper base
Fan Speed1x135mm @ 1400rpm, 1x 120mm @1700
Noise LevelMax 26.1dB(A)
Air Flow67.8CFM
Air Pressure2.1mmH2O
Weight1197g
Up Close
Remember the top of the range Cryorig R1?  Remember how nicely presented and organised the accessories were?  Now have a shufty at the way be quiet present things to you.  Essentially everything has just been stuffed into a cardboard box, which is even too small for the instructions to fit in neatly without getting crumpled up.
CPU Air Cooler Mega Test     CPU Air Cooler Mega Test
The cooler itself though is a thing of beauty, we've long been admirers of the dark sultry looks and imposing presence that is the Pro3.  And we're hopeful that it's twin stack layout and combination of high speed 120mm and lower speed 135mm fans will garner some decent performance results.
The 7x6mm heat pipes are spread evenly between the twin towers allowing for maximum heat transfer into the stacks, with the front 120mm fan covering the whole of the front of the first stack, and the larger 135mm fan dropping down lower and providing air to the rear stack.
The top of the Pro3 is finished in a thick stepped Aluminium billet bearing the bequiet logo in chrome.  Underneath, it's nice to some quality work on the heat pipes, contact plate and fin stack.
So how does it perform?  Well as you might guess if you've read the other bequiet reviews, not very well at all.  It manages to come in slightly on the right side of the half way mark in the 4,7GHz test, which although not bad is astonishingly bad for a twin stack cooler of this size.  Look at the cooler that's immediately ahead of it in the test...Yes that's right, the 92mm fan based Noctua NH-U9S outperforms the twin stack twin fan based Pro3.  On the plus side, we do have to be honest and say that we really love the look of the Pro3, it just has such fantastic case presence.  We think it's a real shame that the bequiet coolers don't perform as expected, and although we can't be sure our hunch is that the lacklustre performance is related to two factors.  he first of these is that feel the quiet fan technology isn't up to the job of pushing the air through the large finstack sufficiently even if it is quiet anyone can make a fan that doesnt push any air and just rave about its silence.  The second is that even with everything tightened down as far as it will go the contact plate doesn't have a firm enough contact with the CPU lid and that is despite fitting it correctly and making sure it was as tight as everything could go. All fittings were done up to the stoppers where the thread runs out, short of adding in our own spacers there was no way to get this mounted any tighter.  A form of compression spring as seen with many other coolers may well help, and it's a development we'd love to see.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 Next»
10-08-2016, 14:32:21
shambles1980
Had a quick look..
dont see any AIO's in there as a comparison.. I think it would have been nice to see atleast 1-2 of the most popular ones in there, it would just round out the comparisons a bit better imo if you also factor noise efficiency and redundancy.Quote
10-08-2016, 14:36:41
PixxHD
Great article, good to see my D15 is still a beast in the air cooled department.
One small thing, while reading the D15 page I couldn't help but notice something wrong.
With the front fan installed you are though limited to standard height RAM.
This is actually not the case, the fan can be positioned forward due to the design of the mounting which allows for big RAM if you have the case clearance for the fan to protrude off the cooler.Quote
10-08-2016, 14:52:00
Spiderz
That explains all the hype around the Cryorig lot, good prices and performance there. Great to see so many all together in one place for comparison.Quote
10-08-2016, 14:53:46
Helix
The BeQuiet coolers are meant to be tightened from the back of the motherboard, not above and between the fins. No wonder you found it hard to do.. If you are saying that poor fitting is the reason they don't perform well, then the test results are not representative of the coolers performance.Quote
10-08-2016, 15:08:21
The_Governour
I bought the Be Quiet Dark Rock TF for the looks for the Lian Li Q10 build - was supriced that it placed so low.
Have the Raijintek Pallas on my living room rig cooling a G3258 and I thought it was great.Quote
