CPU Air Cooler Mega Test
Raijintek Pallas
Raijintek Pallas
Price:  £29.99
Technical Specification
Dimensions153x68x150mm (HxWxD)
CPUIntel: 775,1150, 1151, 1155, 1156, 1366, 2011/v3.  AMD: FM1, FM2/+, AM2/+, AM3/+
Heat pipes6x6mm copper pipes
Fins61
MaterialsAluminium fins, Copper base
Fan Speed1x140mm fan @1400
Noise LevelMax 28dB(A)
Air Flow56.55CFM
Air Pressure1.24mmH2O
Weight420g (without fan)
Up Close
The low and flat orientation of the box hints at the Pallas being a low profile cooler, and indeed it is.  Along with a 1400rpm low profile fan you also get a "big-bag-o-screws" to wade through to find the fittings you need for the varienty of Intel and AMD sockets the Pallas is designed to fit.  What is worrying is that it appears to be the same method as used on the Themis and the thought of tackling this fitting system again fills us with dread
CPU Air Cooler Mega Test     CPU Air Cooler Mega Test
The Pallas arrived in much better condition than the Themis, with not a hint of a bent fin to be found, but then, the fins do appear to be thicker and more substantial anyway.  The fan spring clips however are far from substantial, and about the most ill fitting and awkward to use we've ever come across.  You practically have to break things to get them on, and once on they are near impossible to remove without ripping a nail off or gouging yourself open.
Raijintek have managed to cram no less than 6x6mm copper pipes into the Nickel plated copper contact plate, which is no mean feat.  It's also nice to see that things are clean and tidy down here, which alludes to a more stringent (or lucky) quality control process for the Pallas.
I'd really like to meet the sausage womble that designed the fitting system for the Pallas and for that matter all the other Raijintek coolers.  I'd sit him down with a Noctua cooler and show him the similarities between his design and the Noctua and show him just how easy it would have been for him to achieve perfection, then i'd slap him around the head with the cooler to emphasis just how far away he managed to fall.  Another point worth mentioning is that as this is a low profile top down cooler it offers cooling to the near socket motherboard components.  If you're wondering why we've got it mounted the way we have, the answer is simple.  We couldn't mount it with the fin stack overlapping the RAM, not because it was too low (although it was damned close), but because the end of the heat sink stuck out so far that it fouled the 24pin cable and socket.  |n terms of performance, the Pallas faired slightly better than the Themis but still not brilliantly in terms of it's overall and divisional standings.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 Next»
10-08-2016, 14:32:21
shambles1980
Had a quick look..
dont see any AIO's in there as a comparison.. I think it would have been nice to see atleast 1-2 of the most popular ones in there, it would just round out the comparisons a bit better imo if you also factor noise efficiency and redundancy.Quote
10-08-2016, 14:36:41
PixxHD
Great article, good to see my D15 is still a beast in the air cooled department.
One small thing, while reading the D15 page I couldn't help but notice something wrong.
With the front fan installed you are though limited to standard height RAM.
This is actually not the case, the fan can be positioned forward due to the design of the mounting which allows for big RAM if you have the case clearance for the fan to protrude off the cooler.Quote
10-08-2016, 14:52:00
Spiderz
That explains all the hype around the Cryorig lot, good prices and performance there. Great to see so many all together in one place for comparison.Quote
10-08-2016, 14:53:46
Helix
The BeQuiet coolers are meant to be tightened from the back of the motherboard, not above and between the fins. No wonder you found it hard to do.. If you are saying that poor fitting is the reason they don't perform well, then the test results are not representative of the coolers performance.Quote
10-08-2016, 15:08:21
The_Governour
I bought the Be Quiet Dark Rock TF for the looks for the Lian Li Q10 build - was supriced that it placed so low.
Have the Raijintek Pallas on my living room rig cooling a G3258 and I thought it was great.Quote
