CPU Air Cooler Mega Test
Raijintek Ereboss
Raijintek Ereboss
Price:  £35.22
Technical Specification
Dimensions160x140x110.5mm (HxWxD)
CPUIntel: 775,1150, 1151, 1155, 1156, 1366, 2011/v3.  AMD: FM1, FM2/+, AM2/+, AM3/+
Heat pipes6x6mm copper pipes
Fins33
MaterialsAluminium fins, Copper base
Fan Speed1x140mm low profile fan @1400rpm
Noise LevelMax 28dB(A)
Air Flow56.55CFM
Air Pressure1.24mmH2O
Weight808g (without fan)
Up Close
Well you might still get the bag-o-bolts approach to accessories but you also get a Noctua Style Long screw driver to help with what promises to be an arse of a fitting process.
CPU Air Cooler Mega Test     CPU Air Cooler Mega Test
The cooler itself is quite a chunky monkey, measuring as it does 160x140x110.5mm (HxWxD).  Raijintek have tried to limit the front overhang though by fitting it with one of their 13mm thick low profile 140mm fans.
As you can see, the 140mm fan somewhat overlaps the 33 element fin stack.  It's also worth noting that although some of the heat pipes are located slightly more medially, they are all still essentially positioned towards the lateral aspects of the stack.
Again quality isn't exactly brilliant on the Ereboss.  We found that the upper most Aluminium fin was actually domed slightly, and as this is the bit of the cooler you actually see when it's in your case it does rather detract from the aesthetic.  There was also quite a bit of solder splatter onto the copper heat pipes, as well as a small divot missing from the contact plate.  Not good Raijintek, Not good at all.
As suspected, fitting the Ereboss was an absolute nightmare, taking a good 20 mins and a lot of Effing and Jeffing.  The supplied long screw driver did make the process possible, because were it not for it there's no way you could fit the cooler with a standard screwdriver, but as the drive bit on the end of it was far too big for the screws it was going into it was difficult to get good purchase on the screw heads and as a result we weren't able to get it clamped down as much as we'd like to.  This lack of pressure we think is reflected in the poor performance garnered by the Ereboss, coming as it does last in the 140mm fan based cooler division, and a full 11.5 degrees behind the much smaller NH-U14S.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 Next»
10-08-2016, 14:32:21
shambles1980
Had a quick look..
dont see any AIO's in there as a comparison.. I think it would have been nice to see atleast 1-2 of the most popular ones in there, it would just round out the comparisons a bit better imo if you also factor noise efficiency and redundancy.Quote
10-08-2016, 14:36:41
PixxHD
Great article, good to see my D15 is still a beast in the air cooled department.
One small thing, while reading the D15 page I couldn't help but notice something wrong.
With the front fan installed you are though limited to standard height RAM.
This is actually not the case, the fan can be positioned forward due to the design of the mounting which allows for big RAM if you have the case clearance for the fan to protrude off the cooler.Quote
10-08-2016, 14:52:00
Spiderz
That explains all the hype around the Cryorig lot, good prices and performance there. Great to see so many all together in one place for comparison.Quote
10-08-2016, 14:53:46
Helix
The BeQuiet coolers are meant to be tightened from the back of the motherboard, not above and between the fins. No wonder you found it hard to do.. If you are saying that poor fitting is the reason they don't perform well, then the test results are not representative of the coolers performance.Quote
10-08-2016, 15:08:21
The_Governour
I bought the Be Quiet Dark Rock TF for the looks for the Lian Li Q10 build - was supriced that it placed so low.
Have the Raijintek Pallas on my living room rig cooling a G3258 and I thought it was great.Quote
