CPU Air Cooler Mega Test
SilverStone Heligon HE01
Price:  £71.36
Technical Specification
Dimensions164x140x122(HxWxD)
CPUIntel: 775,1150, 1151, 1155, 1156, 1366, 2011/v3.  AMD: FM1, FM2/+, AM2/+, AM3/+
Heat pipes6x6mm Copper pipes
Fins2x47
MaterialsAluminium fins, Copper base
Fan Speed1x140mm fan @2000rpm (performance) or @1200rpm (Quiet)
Noise Level41dB(A)
Air Flow171CFM
Air PressureNot Given mmH2O
Weight926 without fan
Up Close
Well it's back to the brown box packaging for the Heligon series.  Although we haven't shown the accessories box you do get quite a bit of stuff.  Along with the usual fitting kits and universal back plate there's also a syringe of TIM as well as three sets of spring clips.  This means that should you choose to you could actually mount a total of 3x140mm fans to this cooler.
CPU Air Cooler Mega Test     CPU Air Cooler Mega Test
The HE01 is based on the 140mm fan, but the unit that comes with it is a little different from the usual fayre.  Not only is it super thick, but it has a variable speed control which enables full PWM control with a max speed of either 2000 rpm in performance mode or a more sedate 1200rpm in quiet mode.  The mode is selected by means of a small switch on the fan cowling.
The HE01 has two fin stacks of 47 elements each, with the anterior fin stack being about half the thickness of the posterior one so as to mitigate any RAM encroachment issues.  We have to say we particularly like the thick fan and the way it completely fills the gap between the two stacks, this is something we've not seen before and we're kinda a bit hopeful that the 171CFM of air generated by the fan at 2000rpm will translate into some awesome cooling figures.
On the image below left you can clearly see the small fan mode selection switch.  Flipping the cooler over to look at the underside we can see that the contact plate has 6x6mm heatpipes eminating from it.  Also of note is that the pipes are oriented both laterally and antero-posteriorly within the fin stack
The  HE01 was really very easy to fit, but left us with the feeling that even at full tension it wasn't clamped down as tightly as it could have been.  This lack of a good firm contact can often translate into poor performance as the contact plate fails to effectively conduct the heat away from the CPU.  As suspected the HE01 failed to perform as well as it potentially could have done, coming 2nd from bottom in its class and just below the half way point in the overall standings.  I guess we were right about the lack of contact having an effect on performance.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 Next»
10-08-2016, 14:32:21
shambles1980
Had a quick look..
dont see any AIO's in there as a comparison.. I think it would have been nice to see atleast 1-2 of the most popular ones in there, it would just round out the comparisons a bit better imo if you also factor noise efficiency and redundancy.Quote
10-08-2016, 14:36:41
PixxHD
Great article, good to see my D15 is still a beast in the air cooled department.
One small thing, while reading the D15 page I couldn't help but notice something wrong.
With the front fan installed you are though limited to standard height RAM.
This is actually not the case, the fan can be positioned forward due to the design of the mounting which allows for big RAM if you have the case clearance for the fan to protrude off the cooler.Quote
10-08-2016, 14:52:00
Spiderz
That explains all the hype around the Cryorig lot, good prices and performance there. Great to see so many all together in one place for comparison.Quote
10-08-2016, 14:53:46
Helix
The BeQuiet coolers are meant to be tightened from the back of the motherboard, not above and between the fins. No wonder you found it hard to do.. If you are saying that poor fitting is the reason they don't perform well, then the test results are not representative of the coolers performance.Quote
10-08-2016, 15:08:21
The_Governour
I bought the Be Quiet Dark Rock TF for the looks for the Lian Li Q10 build - was supriced that it placed so low.
Have the Raijintek Pallas on my living room rig cooling a G3258 and I thought it was great.Quote
