CPU Air Cooler Mega Test
Scythe Mugen Max
Scythe Mugen Max
Price:  £37.99
Technical Specification
Dimensions110x145x161(HxWxD)
CPUIntel: 775,1150, 1151, 1155, 1156, 1366, 2011/v3.  AMD: FM1, FM2/+, AM2/+, AM3/+
Heat pipes6x6mm Copper pipes
Fins40
MaterialsAluminium fins, Copper base
Fan Speed[email protected]
Noise Level30.7dB(A)
Air Flow97.1CFM
Air Pressure1.02 mmH2O
Weight720g without fan
Up Close
Scythe don't do subtle and understated.  Scythe do "in your face".  On the plus side the box has lots of info on it regarding the product inside, and even has a shelf hanger tab, you know, for when you used to buy things in shops.  But hey, just check out that mirror finish, it's seriously different and gets a thumbs up (and most likely a thumb print) from us.
CPU Air Cooler Mega Test     CPU Air Cooler Mega Test
Measuring 110x145x161mm (HxWxD) the Mugen Max is a 140mm fan based single tower cooler.  The single black fan is lifted just slightly from the standard OEM fayre and looks the part.
The 6x6mm heat pipes are evenly distributed within the 40 element fin stack both antero-posteriorly and laterally, which, from our experience usually results in better performance figures.  Also of note is that the fin stack is canted backwards to be asymmetrical with the contact plate.  this of course limits RAM encroachment once the fan is fitted.
Sadly the picture below doesn't do the mirror finish on the top plate justice, but believe us when we say it is a thing of beauty.  We also like the way it covers up the tops of the heat pipes and thus improves the overall aesthetic.  Down below we can see the quality of work is good with even the contact plate being highly polished.
When I opened the accessories and fittings bags my heart sank at the sight of a tiny spanner.  If testing all these coolers has taught me one thing, it's that if it needs a small spindly spanner to fit it, it's going to be a sod!  What I didn't appreciate though was just how much of a sod it was going to be.  Basically it's practically impossible to fit as the bolt that resides under the rear of the heatsink is so close to the motherboard heat sink that it's near impossible to see it, never mind get the spanner to it.  then I spotted the hole in the fin stack that channels down to it so thought "I know, i'll attach the bolt to my magnetic tipped screw driver and lower it down".  Great idea, only Scythe have made the hole too small for the bolt to fit down.  Genius, pure bloody genius.  Long story short, in the end I had open back up one of the Noctua boxes to extract one of their very long screw drivers.  So in essence, if you're going to buy this cooler, you're going to need a very long nosed screwdriver and a sense of adventure.  Unlike the hard to fit bequiets however, the Mugen Max rewarded us with some stunning performance figures, coming 2nd place in its class and 7th overall.  Not bad for a cooler that cost's just £38.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 Next»
10-08-2016, 14:32:21
shambles1980
Had a quick look..
dont see any AIO's in there as a comparison.. I think it would have been nice to see atleast 1-2 of the most popular ones in there, it would just round out the comparisons a bit better imo if you also factor noise efficiency and redundancy.Quote
10-08-2016, 14:36:41
PixxHD
Great article, good to see my D15 is still a beast in the air cooled department.
One small thing, while reading the D15 page I couldn't help but notice something wrong.
With the front fan installed you are though limited to standard height RAM.
This is actually not the case, the fan can be positioned forward due to the design of the mounting which allows for big RAM if you have the case clearance for the fan to protrude off the cooler.Quote
10-08-2016, 14:52:00
Spiderz
That explains all the hype around the Cryorig lot, good prices and performance there. Great to see so many all together in one place for comparison.Quote
10-08-2016, 14:53:46
Helix
The BeQuiet coolers are meant to be tightened from the back of the motherboard, not above and between the fins. No wonder you found it hard to do.. If you are saying that poor fitting is the reason they don't perform well, then the test results are not representative of the coolers performance.Quote
10-08-2016, 15:08:21
The_Governour
I bought the Be Quiet Dark Rock TF for the looks for the Lian Li Q10 build - was supriced that it placed so low.
Have the Raijintek Pallas on my living room rig cooling a G3258 and I thought it was great.Quote
