CPU Air Cooler Mega Test
Cryorig R1 Universal
R1 Universal
Price  £71.34
Technical Specification
Dimensions168.3x140x128.5mm (HxWxD)
CPUIntel: 1150, 1151, 1155, 1156, 775, 1366, 2011/v3.  AMD:  FM1, FM2/+, AM2/+, AM3/+
Heat pipes7x6mm copper pipes
FinsFront Stack=42x0.4mm thick, 2.4mm gap.  Rear Stack=53x0.4mm thick, 1.8mm gap
MaterialsAluminium fins, copper base
Fan Speed[email protected]
Noise LevelFront max 24dB(A) Rear fan 23dB(A)
Air FlowFront fan 65CFM Rear Fan 76CFM
Air PressureFront Fan 1.49mmH2O.  Rear Fan 1.44mmH2O
Weight1215g
Up Close
When I received the R1 for testing I remembered what Tom had said to me on the phone a few days earlier  "If you like the quality of Noctuas, you're going to love the R1".  I have to admit to not really following what he meant, that was until I started to unbox the R1.  The first thing that greets you when you pop open the lid is a slide out compartmentalised tray that contains all the fittings you could ever need for a whole host of Intel and AMD chips.  You also get a sealed warranty card and instructions, as well as additional spring clips, vibration dampeners, a fan splitter, a screw driver, a tube of TIM, a cuddly toy, a fondue set and a picnic hamper.  OK, so you don't get the last 3, and you'll have to be the wrong side of 40 to get the reference, but you get the idea.
CPU Air Cooler Mega Test     CPU Air Cooler Mega Test
The R1 Universal is an almost identical model to the R1 Ultimate that we'll see on the next page.  The variance of course being that it has a low profile front fan which will enable it to be compatible with any RAM as it won't overhang the first RAM slot.
The cooler is a bit of a hotch potch of colours, moving from a grey front fan, through a white cowling, to a black fin stack, then to another grey fan and white cowling before terminating in a black fin stack.  Viewed from the rear however we can see that the seven heat pipes are very well distributed into the stack, which should greatly aid heat transfer.  What isn't immediately obvious from these images is that the number of fins and thus fin spacing differs between the two fin stacks, with the rear stack having more fins, more tightly stacked than the front.  The idea here is that as the air is compressed it will be forced to leave the stack more quickly and so aid cooling.  Cryorig have dubbed this their Jet Fin Acceleration System.
Here we can again see the striation of colours as we move across the top of the stack, along with the way the heat pipes are displaced antero-posteriorly within the stack as well as being laterally separated.
The R1 fills a good chunk of the interior of our new test rig, but was actually one of the easiest coolers in the Cryorig group to fit, thanks to the "Multi Seg" Quick mount system.  Although it's massive, a quick zoom into the front fan area does in fact reveal that there is no encroachment on the RAM slots, meaning that as stated there's a 100% RAM compatibility.  If though you're mounting this on a 2011 board, or anything else that has an additional set of RAM slots towards the rear of the Motherboard, you might want to remember the 35-40mm RAM height limit does still apply round the back of the cooler.  As anticipated, the R1 universal did well in the torture tests coming fifth overall and only 2.5 Degrees off the all conquering NH-D15.  Not bad for a cooler that can be used with tall RAM.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 Next»
10-08-2016, 14:32:21
shambles1980
Had a quick look..
dont see any AIO's in there as a comparison.. I think it would have been nice to see atleast 1-2 of the most popular ones in there, it would just round out the comparisons a bit better imo if you also factor noise efficiency and redundancy.Quote
10-08-2016, 14:36:41
PixxHD
Great article, good to see my D15 is still a beast in the air cooled department.
One small thing, while reading the D15 page I couldn't help but notice something wrong.
With the front fan installed you are though limited to standard height RAM.
This is actually not the case, the fan can be positioned forward due to the design of the mounting which allows for big RAM if you have the case clearance for the fan to protrude off the cooler.Quote
10-08-2016, 14:52:00
Spiderz
That explains all the hype around the Cryorig lot, good prices and performance there. Great to see so many all together in one place for comparison.Quote
10-08-2016, 14:53:46
Helix
The BeQuiet coolers are meant to be tightened from the back of the motherboard, not above and between the fins. No wonder you found it hard to do.. If you are saying that poor fitting is the reason they don't perform well, then the test results are not representative of the coolers performance.Quote
10-08-2016, 15:08:21
The_Governour
I bought the Be Quiet Dark Rock TF for the looks for the Lian Li Q10 build - was supriced that it placed so low.
Have the Raijintek Pallas on my living room rig cooling a G3258 and I thought it was great.Quote
