Enermax ETS-T40 CPU Cooler
Up close
Published: 21st November 2011 | Source: ENERMAX | Price: £34.99 |
Up Close
The Cooler comes securely packaged in a cardboard box and although there's no window through which to see the goodies inside the box the simple blue and white exterior shows us an image of the product as well as as detailing tech spec and key features.
Opening the box we find the cooler snugly nestled in a supportive cardboard framework, with instructions and accessories stored in their own separate compartment off to the side. At this point it's also worth picking up on the point that that Enermax have factory fitted the fan to the cooler, saving you at least one step in the installation process.
Once extracted from the box we get a better view of the Cooler itself. It's a medium sized cooler, being only 70mm deep (excluding the fan). Build quality and finish appear to be very high, the Nickel plating is near perfect and the there's no evidence of bent fins.
The ETS-T40 uses a direct contact heat-pipe approach to thermal transfer, utilising 4x 6mm copper pipes. These pipes in turn feed up through Aluminium fins to complete the thermal transfer cycle.
Excellent review Gary ![]() I really like the looks of this cooler and it would be interesting to see how it performs on the Sandy Bridge line. |
I really like the looks of this cooler and it would be interesting to see how it performs on the Sandy Bridge line.Quote
