EVGA CL28 AIO Watercooling Review
Performance and Testing
EVGA CL28 Review
The test set up consisted of the following
Intel Kaby Lake i7 7700K
4.8GHz @ 1.25v, 5.0GHz @ 1.3v
Asus Maximus VIII Ranger
2x8GB Corsair Vengeance LPX Memory 3200MHz
CoolerMaster V650
Corsair Force GT 60GB
Coolermaster MasterCase Pro5
As was the case with our previous set up, we'll be testing our coolers at varying levels of overclock and increasing levels of voltage. The increase in volts means an increase in heat within the CPU, and it's this heat that the coolers need to dissipate.
Continuity is very important in testing, and for this reason we keep as many of the potential variables as locked down as possible.  We will be using OCCT in Linpack X64, AVX compatible with all logical cores tested and 90% free memory utilised. The test is set up to run automatically with just a few clicks to set it going.  A 10 minute idle followed by 30 minutes of testing and a 5 minute cool down is the order of the day and brings the total test time per clock speed to 45 minutes.  So as to remove subjectivity in determining whether a CPU has failed, OCCT is set to stop the test and register a fail should the max temp exceed 80 degrees.  As with the socket 2011, in testing we noted that if even just one of the cores exceeds 82 degrees OCCT halts the test and a fail is recorded.
4.8GHz
Having had a fiddle with the volts we achieve a nice stable 4.8GHz overclock at 1.25 Volts (stock for most boards).  This level of overclock is going to give us a pretty good idea of how well coolers will perform when under a bit of stress.  We'd expect everything to make it through, however some may come close to the automatic 80 degree cut off wire.
EVGA CL28 Review
5.0GHz
A bump to 1.3v saw us acheive a solid 5.0GHz Overclock.  Only the very best coolers are going to perform well with this amount of heat being pumped into them, and even then, some of them will be close to the automatic cut off point.  5.0GHz might not seem like a huge increase on 4.8GHz, but the additional heat generated by that seemingly small bump in core voltage does seem to challenge the coolers that bit more, and so as before it's here we start to separate the men from the boys, as lesser coolers may not able to disperse the increased heat effectively.  Only the cream of the crop will excel at this level.
EVGA CL28 Review
Sky Lake Testing
     Intel i7 6700K Stock (4.2GHz)@ 1.2v, 4.6GHz @ 1.3v, 4.7GHz @ 1.344v, Asus Maximus VIII Ranger, 2x4GB Corsair Vengeance LPX Memory CoolerMaster V650, Corsair Force GT 60GB Coolermaster MasterCase Pro5
4.7GHz
Skylake if you remember didnt overclock as well as Kaby Lake and needed a fair few volts for what now seems like a 'low' 4.7GHz overclock. We only still run this because we can use the same test rig for it and it helps us still include a lot of results in the graph, if nothing else its great for cross referencing. To be very clear though only the cream of the crop will excel at this level.
EVGA CL28 Review
«Prev 1 2 3 4 5 6 7 8 Next»
26-05-2017, 05:06:36
tinytomlogan
26-05-2017, 05:48:55
Seikusa
Since the fans somewhat blow the air sidewards (JTC did testing with with liquid ice https://www.youtube.com/watch?v=5p2rkH4G-hs ). How did it perform with your standart vardar fans?Quote
26-05-2017, 12:15:26
crobbot
Does the video answer the question? IMHO no it does not. JTC does like the sound of his own voice. Cool video though. Quote
29-05-2017, 09:00:41
SilentForever
Originally Posted by tinytomlogan View Post
Tom, any chance of adding nzxt x52 results into the graph? Thanks for including the x62 btw. Really helpful Take care Quote
05-06-2017, 12:18:29
Platinum
Just had an email to say I have won the 280 one, well chuffed with that Quote
