Fractal Define Nano S ITX Case Review
Up Close: Â Interior
Popping off the side panels shows us that the acrylic window is held in with metal pegs. Â This might not seem like a big deal, but if you’re into modding this sort of thing is nice to know. Â The right hand side panel though is lined with sound absorbing material.
Â
After seeing so many M-ITX cases with weird and wonderful layouts, it actually feels a little odd to see one laid out as a smaller version of an ATX format case. Â We’re not sure whether this represents, as Fractal would claim “A new way too look at the ITX form factor” though. Â OK, so let’s get down to the detail shall we. Â There’s a decent sized CPU cut out, which has a large removable panel across most of it’s area. Â This as we’ll see later is for mounting SSDs on the rear of Motherboard area.
Â
The Nano S has a fair few grommeted cable management holes although they are on the small side. Â Of particular concern is the bottom most hole which is intended for the PSU cables to leave on their way rearward. Â Now Fractal say that a PSU of up to 160mm will be fine here, but we can’t help thinking that it will obscure some of this management hole. Â Guess we’ll see when it comes to the build
Â
The vertical slots in the side of the motherboard panel are actually to allow reservoirs to be mounted and located in the optimum position for the user. Â Fractal have certainly given us plenty of choice. Â At the front of the case we find a 140mm GP14 fan, although should you wish you can mount either a pair of 120s or a pair of 140s. Â Again, Fractal provide slots to enable the fan positions to be altered if needed.
Â
Down in the base of the case lurks a bracket that is intended to enable mounting of a variety of pumps (including DDC and D5 types) or a solitary HDD. Â Again, the position can be altered using the slots. Â The PSU lives at the rear and sits on four slim foam pads.Â
Â
At the rear there’s the 140mm GP12 fan, the same as in the front but smaller. Â Up in the roof we see a pair of small grommeted cable management holes and the plastic studs that retain the ModuVent roof panel.
